Cities on wheels.
All  1-2  3-11
8029.3
Yep, that's definitely nurnies on steroids! Fascinating.
I suppose you set up different rules for altitude and slope, sorta like what it done when creating ecoSystems in Vue. Snow on flatter areas, rocky details on more verticals-- with higher snow/rock ratio the higher you go on a mountain.
I'm wondering, do you also create *different* buildings based on some rules?
Thanks for sharing!!!!
8029.4 In reply to 8029.3
About 10 years ago, I was trying to do something similar, but not so successful. The idea was to use fractal distribution patterns to create ultra-greeble detailed models. Hope you don't mind me sharing, here are a few of my attempts:
Using random transparency 'grid patterns' to create transparency in building structure.
Using ecoSystem distribution to combine basic geometries using hyperblobs to create vehicles
Using hypertextures (volumentric fractal solids) to create a vehicle
Using massive ecosytems distributions to create near orbit alien 'thing'
8029.5
There are all kinds of shades of badass in that post PAQ, amazing work buddy.
Martin
(TpwUK)
8029.6
Thanks guys,
Hi chipp,
Well that's some really nice results, actually I haven't think about playing with transparency alpha's (I will probably use clip map to speed up the raytracing).
As for the rules, originally building where indeed using a slope angle rule, but I change my mind after few population test and decide to give the exact areas 'by hand', by isolating some poly's.
There is only 'one' type of building, but off course the floors numbers and windows position are based on their height. Finding a good balance between chaos and structure is really tricky.
(I still have many stuff to learn in that area :)).
8029.7 In reply to 8029.6
Very cool and inspiring — ! — thank you for sharing — !
8029.8 In reply to 8029.6
Yes, that is always the big challenge-- one I don't think I ever solved. Most stuff I did always look too algorithmic. Yours looks much better!
I'm wondering if any of this might be able to be done using Max's node editor inside of MoI?
@PAQ
Very impressive!
I have found this old one!
http://baguenaudes.net/category/mines/
8029.10 In reply to 8029.9
one question about this awesome work
wich software is used for render like that ?
Size: 921.6 KB, Downloaded: 50 times, Dimensions: 1278x706px
8029.11 In reply to 8029.10
Seems it was writed "Clarisse" ?
Show messages: All  1-2  3-11
