Slice Script for MOI 3D
All  1  2-8
7977.2 In reply to 7977.1
DON'T make A Trim ! A Trim makes "Open Volumes"!
Make a multiple Boolean Diff and all wil works like a charm! ;)
Then Select All and Press TAB and write ExplodeMove! :)
(that I made during the 5 seconds time of the pause's Animation following)
EDITED: 4 Jun 2016 by PILOU
7977.4 In reply to 7977.2
Thank you so much, you solved my problem.
Thanks again.
EDITED: 4 Jun 2016 by RAYCAD1962
7977.5 In reply to 7977.1
Hi Ray, it sounds like you've got the slicing covered, but just to make sure yes like Pilou write above you can use boolean difference to slice a solid with a 2D curve including a set of lines and the booleans are oriented around keeping things solid so the lines will leave the "side walls" where they cut, resulting in solid sliced results unlike Trim.
For a thread script, see the "Nuts and bolts" script from Max's page here: http://moi.maxsm.net/media/files/
Also some other scripts are collected here: http://kyticka.webzdarma.cz/3d/moi/ and instructions for installing a script are in the FAQ here: http://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
7977.6 In reply to 7977.5
Thank you for your helpful help that you gave me. Without you I can't menage. I know AutoCAD but MOI 3D is something for me when I discover it. It's so powerful that you have Moment of Inspiration for me is a good title.
Thanks again for your expertise in the MOI 3D.
Ray
7977.7 In reply to 7977.6
After AutoCad Moi is a sugar candy!:)
7977.8 In reply to 7977.6
You're welcome Ray, and I'm glad that you are liking MoI!
Show messages: All  1  2-8
