New Tutorial for removing fillets in MoI
7925.1
Hi everyone. Long time since I last created a tutorial but Frenchy's post really got me thinking and I had to try out the SeparateSelectOuterLoopsDeleteTrim.js command and see how it works. More on that command and how to download it here.
In the video I show where I use a keyboard command (shift-]) to select a loop of edges once two or more are selected. I can't remember where I found it, or who wrote it. Apologies, but here's the keyboard shortcut:
script:/*Loop selection*/moi.geometryDatabase.SelectLoop();
This is a short video which demonstrates both a manual method for removing fillets (and holes) and then the more automated version using the command mentioned above.
7925.2 In reply to 7925.1
EDITED: 20 Apr 2016 by PILOU
7925.3 In reply to 7925.2
I am on a Mac running 3.1. I installed your script but it doesn't show up under external scripts. It will show up in 3.0. Am I putting the script into the wrong place?
7925.4
It goes in this folder:
/Applications/MoI v3.1.app/Contents/Resources/drive_c/moi/commands/
7925.5 In reply to 7925.3
Hi Mike, if you've got the script just pasted into a shortcut key, I think Max's scripts menu only shows shortcut keys that are marked with a ! character in a comment in the shortcut script, as a way of controlling which ones are shown.
See the instructions on this other shortcut menu for more explanation:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5993.1
7925.6 In reply to 7925.5
Thank you. After attempting this I get the following error message.
EDITED: 20 Apr 2016 by HOPPER
Size: 25.7 KB, Downloaded: 29 times, Dimensions: 292x191px
