Using PatterNodes to Create a Speaker Grill Detail
 1-8  9-28  29-48  49-58
7745.9
Great stuff -- thank you for sharing.
7745.10
RadialPattern v.1.2
Added:
- custom shapes support (select any object before the script run)
- click on title to randomize values
EDITED: 7 Mar 2022 by SMIRNOV
7745.11 In reply to 7745.10
SWEET! I was thinking about asking you for custom shapes. SUPER!!!!
Thanks Max :-)
7745.12 In reply to 7745.10
If you select nothing, the first time at the lauch of MOi there an alert message!
Cool even volumes! :)
French Version
http://moiscript.weebly.com/scripts-de-max-smirnov.html
EDITED: 5 Dec 2015 by PILOU
7745.14
Use of Max's new RadialPattern script:
EDITED: 6 Dec 2015 by CHIPPWALTERS
Rolling wheels! :)
7745.16
Excellent script, as usual.
Thanks a lot MAX.
Mik
7745.17
bugfix update
v.1.3
7745.18 In reply to 7745.17
7745.19
Max Smirnov,
Thank you for the free use of your many scripts, especially the RadialPattern script!
I salute your generosity and hope that good fortunes will soon offer me an enhanced capacity to reciprocate.
Regards,
-- Mindset
EDITED: 26 Jan 2017 by IGNITER
Flashy!
7745.21
In search for a solution for a pattern design I came across this great script.
My question is : I need equidistant gaps between the multiplied objects -
is this achievable wit this script ?
Or achievable by other means ?
Best TOM
7745.22 In reply to 7745.21
I don't know what is the nature of your object result but if you press Tab then write ExplodeMove (without space) maybe you will have your result wanted! ;)
Explode Move is hidden function but integrated inside the Native Moi3D !
Else you can recreate all the plugin PatterNodes or what anything you want exactly with ELEPHANT! ;)
http://moiscript.weebly.com/biblio-elephant.html
EDITED: 27 Sep 2019 by PILOU
7745.23 In reply to 7745.22
Thank you Pilou, I tried it out but nothing happened - I need to take a closer look how this script works.
I am attaching a pattern like the one I want to achieve / create variations.
7745.24 In reply to 7745.23
Maybe "Separe" your result before use Explodemove!
7745.25 In reply to 7745.23
There is a hex pattern on the grill. Used NodeEditor with a modified HexTesselation macro and James's FishEye Node. Not quite right on hole sizing.
EDITED: 17 Jan 2021 by WAYNEHILL5202
A pannel of objects
ExplodeMove
Flow on half sphere ;)
7745.27 In reply to 7745.24
I appreciate your help Pilou, but what if the objects get smaller in size like in the photo shonwn ?
7745.28 In reply to 7745.25
Hi, first time I here about a hextessekation macro, can you tell me where I can find it ?
Show messages:  1-8  9-28  29-48  49-58
