model canopy
All  1-5  6-15
7717.6
Why don't you use Network ?
I've tested with a little example in attachment
EDITED: 9 May 2020 by FINEMA
7717.7
you can also use Loft to design the general model and Boolean >Diff to cut the cockpit
PS : sorry for my poor design , i'm haven't time to do the same as you request.... :)
7717.8
Hello,
Video is up showing one way to model the fuselage. It's not entirely complete but I didn't want to run the video much past 30 minutes. Hope it helps explain the concepts at very least.
https://vimeo.com/145704021
7717.9 In reply to 7717.8
Really instructive.
Thanks for this video OsTexo.
7717.10 In reply to 7717.9
application of your tutorial >
7717.11 In reply to 7717.4
WOW!! Yes indeed
Such help I never expected
7717.12 In reply to 7717.8
Great tutorial. Learned some things I didn't know-- esp the 'history' for lines with blend! Thanks for sharing.
7717.13 In reply to 7717.4
Would you mind sharing what software you used to do the rendering
7717.14
Hello,
Thanks, I'm glad it was helpful. As far as the rendering software goes, I use Thea Render with the TR Rhino plugin. In my opinion it is one of the best rendering packages out there and it is really helpful to have the ability to modify the NURBs surfaces and see the render update in real time. I'll make a short video showing this.
7717.15
Wow! That's a very thorough tutorial!
Thanks for taking the time.
I usually work with solids and delete the faces were I want blends.
Your method is quite nice.
On my machine history appears to be on by default.
Blend is such an amazing tool.
Marc
Show messages: All  1-5  6-15
