Layout module for creating documentation in MoI?
All  1-2  3-15
7712.3 In reply to 7712.1
Hi artisanicview,
> I just want to ask if is possible to develop a Layout module (like Sketchup or Rhino
> have) to prepare technical documentation in MoI?
Yes certainly it's possible to develop that for MoI in the future, and it is something that I'd like to add to MoI in the future but it is not something that has been a focus as of yet.
Currently you'll need to use MoI in combination with another program to handle that type of thing, one good option is to export out from MoI in DXF format and then use the free program Draftsight to prepare the documentation.
> Will be tremendously useful to prepare the necessary documentation directly in MoI without the
> need to export the models to other softwares to do this.
Right now it would be necessary to do the export route.
> As I see there is already a script for dimensioning, can this evolve into a full Layout module?
I guess it's possible but it involves quite a lot of work and so I wouldn't really expect for it to happen like that.
7712.4 In reply to 7712.3
Hi
I'm a SKETCHUP and M.O.I user.
I have made , in SKETCHUP , a model witch make an automatic copy of my parts to prepare the dimensioning .
Perhaps , somebody , can make a script in M.O.I to do something like this to prepare the exportation in DXF to DRAFTSIGHT ?
Please , take a look on the next pictures.
Chri
EDITED: 12 Dec 2020 by CHRI
Size: 154.3 KB, Downloaded: 629 times, Dimensions: 1280x767px
7712.5 In reply to 7712.4
Hi Christian, if you'd like to create a script for doing that in MoI you might take a look at the ScriptArray plug-in as a starting point, since it has stuff in it for making moved and rotated copies of objects in it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.18
7712.6 In reply to 7712.5
Hi michael
thé idea is obviously not to create copies of 3D objects, but to reunite these different views for export in dxf.
Thanks for your quick answers. about script.
Chri
EDITED: 7 Nov 2015 by CHRI
7712.7 In reply to 7712.6
Hi Chri - sorry in your labels there I saw you wrote "Copy 90 degrees" and I thought that meant you wanted to make object copies.
Still that may possibly a way to do it, since the DXF export is only set up to export from one view at a time. There isn't anything currently set up for the exporter to use multiple views during the export, so to do a view only one without copying objects I guess you'd need to export to a bunch of different DXF files, one for each view and then maybe read them back into MoI to combine them into one single file I guess.
If you want to try something like that which manipulates the view, see here for some scripts that do some of that type of thing:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4371.2
7712.8 In reply to 7712.7
Hi MIchael
Perhaps , you can write a script witch can export all the view AUTOMATICALLY in one single file and glue them like my layout ?
(excuse me for my language , i'm french)
Chri
Size: 63.2 KB, Downloaded: 21 times, Dimensions: 538x495px
7712.9 In reply to 7712.8
Hi Chri, I'm sorry but I don't have enough time available to work on a script for that myself right now.
But if you want to try working on a script like that yourself, I can try to help you with it if you get stuck.
7712.10 In reply to 7712.9
Hi Michael
I can understand , you have no time for this job , no problem .
it's difficult for me with script , so , i have done it manualy ... and in fact , it's very simple to do it in few click .
here is the method in 3 GIF :
Michael , Thanks again for your help and your magnificent soft.
Chri
Size: 288.6 KB, Downloaded: 580 times, Dimensions: 474x433px
Size: 468.3 KB, Downloaded: 579 times, Dimensions: 520x521px
Size: 322.5 KB, Downloaded: 569 times, Dimensions: 661x477px
7712.11 In reply to 7712.10
A little preliminary study resulted in an outline of a possible script.
Outline for a script to be called LayoutView, November 8, 2015
Assuming the original is located flat in the front view.
Utilize code from ScriptArray, and possibly CenterAtOrigin, Randomize, PutOnGround, etc.
Making 10 copies of the object.
User dialog to select original.
User dialog to select the new location in front view of the layout,
by selecting where the new center point of the original is to be located.
Or its upper left corner? Or have a Checkbox to center at origin?
User has option to select x and y scaling numbers, for the spacing of the views.
var center = objects.getHighAccuracyBoundingBox().center;
center, along with x and y spacing values of the copies,
may be used to establish horizontal and vertical rotation axi.
...BoundingBox().xLength, ...BoundingBox().yLength, and ...BoundingBox().zLength
provide values which may be used to calculate the horizontal and vertical spacing of the various views.
If z value is much larger than x or y, spacing will need to be wide and tall.
Code for copying the original 9 times, and make the appropriate rotations.
7712.12 In reply to 7712.8
Hi Chri,
I've needed same thing...
please see this thread http://moi3d.com/forum/index.php?webtag=MOI&msg=7607.1
maybe it helps you.
Mik
EDITED: 9 Nov 2015 by PILOU
7712.14 In reply to 7712.12
Hi Mik
Many thanks
Make2D is wonderfull ... and MOI incredible .
I often use MOi and always think that MOI is "THE soft to have" .
Many thanks to Mickael
Chri
7712.15
Hi
to create axonometrics views , you can do like this :
Chri
Show messages: All  1-2  3-15
