Export bug?
All  1-9  10-16
7696.10 In reply to 7696.8
FYI, yes, I left it long enough and eventually it *DID* export. :-D
@Chipp
<< The places you point to are obvious errors introduced in Onshape or when exported as STEP from Onshape.
Yon know that you can now also use again 123D Design between Moi for delicate fillets ! ;)
http://www.123dapp.com/design
Because Step / Sat format import export have made their return for Free version! ;)
DIfference than Onshape : it's a local application! ;)
7696.12 In reply to 7696.11
Thanks Frenchy, DID not know that. Much appreciated!
7696.13
FWIW, I really like the Autodesk 123D program. I don't see where it exports STEP, but SAT works fine. I was able to quickly cobble together a basic widget in short order:
Create the basic shape in MoI
Export as SAT to 123D, fillet there using dynamic filleting, and bring back as imported SAT. Next add some kitbash:
Exports as OBJ to KeyShot and VoilĂ
7696.14 In reply to 7696.13
@Chipp
<<I don't see where it exports STEP, but SAT works fine.
Don't know what format is the best for you? :)
But your results seems yet convincing!
PS Free version is of course for no commercial use! ;)
When you press it you have that! :) (Windows user)
EDITED: 1 Nov 2015 by PILOU
7696.15 In reply to 7696.14
Interesting. Mine is different (I'm using free commercial version downloaded from Mac App Store)
7696.16 In reply to 7696.15
@Chipp
Maybe an "advantage" or more "disadvantage"of the Mac World! ;)
In any case one format is yet sufficient for Nurbs world! :)
Show messages: All  1-9  10-16
