OS X El Capitan with MOI
 1-14  15-23
7650.15 In reply to 7650.14
Hi Finema - thanks for testing that. I've got an El Capitan installation set up over here now and I'm able to repeat the same problem. I will look into releasing a new 3.1 version of MoI to fix the viewport maximizing problem so that MoI will then run ok on El Capitan when rootless is disabled.
7650.16 In reply to 7650.15
Ok
thanks Michael
7650.17 In reply to 7650.16
Ok, looks like Wineskin has just been updated to work ok on El Capitan now, so I think I will be able to make a new MoI 3.1 release that should work on El Capitan directly, without needing to turn off rootless or install XQuartz separately.
I'll probably be able to get that set up tomorrow.
7650.18 In reply to 7650.17
great !
7650.19 In reply to 7650.18
Excellent, thanks Michael,
In researching permanently disabling "rootless" the possibility of leaving the system vulnerable felt uncomfortable.
7650.20
Thank you Michael that's great
7650.21
Just a note confirming said behavior. I was able to
csrutil enable
and still the viewports won't expand correctly. I assume there is no current fix for this. Thanks for help solving and really looking forward to the new build. :-)
7650.22 In reply to 7650.21
Hi Chipp,
Yeah there does not seem to be any way to configure things to fix the viewport maximizing thing for the current 3.0 MoI version. Somehow there is different behavior for hiding windows and the windows that are supposed to be hidden (for the other non-maximized viewports) are sticking around.
But it looks like I will be able to do some workarounds in MoI and roll out a new 3.1 version which will then solve it. Also you won't need to mess with disabling rootless either.
I think I'm on track for being able to get that out later today.
7650.23 In reply to 7650.22
Great! Don't worry about the snapshot screen stuff. I'll get it figured out. Thanks!
Show messages:  1-14  15-23
