OS X El Capitan with MOI
 1-9  10-23
7650.10 In reply to 7650.9
Hi Michael, tried the revert Wineskin and instructions to disable "rootless" in terminal.
Window behavior unchanged.
7650.11 In reply to 7650.10
Hi phlatt5th, thanks for trying that. Can you double check the settings in Wineskin (in the Wineskin "Advanced" dialog under Options tab) - the second to last checkbox for "Force use of wrappers quartz-wm ..." should be checked, while the very last one for "Force use of system installed XQuartz ..." should be unchecked.
Is that what you've got?
7650.12 In reply to 7650.11
Hi Michael, when the last one is unchecked it does not launch, see attached screenshot.
7650.13 In reply to 7650.12
Hi phlatt5th,
And that's with "rootless" turned off from a recovery boot?
I'm getting a little confused about what steps you have taken, because above you wrote:
I thought that meant that you were able to launch MoI once the last checkbox was unchecked...
I guess I'll have to get an El Capitan setup over here so I can test it.
7650.14 In reply to 7650.13
rootless turn off on my mac
in terminal and in recovery mode, i've wrote : csrutil disable
the last checkbox is unchecked
It's OK and MoI launch it perfectly BUT the window fullscreen display is damaged again. Only the Right view is OK.
EDITED: 9 May 2020 by FINEMA
7650.15 In reply to 7650.14
Hi Finema - thanks for testing that. I've got an El Capitan installation set up over here now and I'm able to repeat the same problem. I will look into releasing a new 3.1 version of MoI to fix the viewport maximizing problem so that MoI will then run ok on El Capitan when rootless is disabled.
7650.16 In reply to 7650.15
Ok
thanks Michael
7650.17 In reply to 7650.16
Ok, looks like Wineskin has just been updated to work ok on El Capitan now, so I think I will be able to make a new MoI 3.1 release that should work on El Capitan directly, without needing to turn off rootless or install XQuartz separately.
I'll probably be able to get that set up tomorrow.
7650.18 In reply to 7650.17
great !
7650.19 In reply to 7650.18
Excellent, thanks Michael,
In researching permanently disabling "rootless" the possibility of leaving the system vulnerable felt uncomfortable.
7650.20
Thank you Michael that's great
7650.21
Just a note confirming said behavior. I was able to
csrutil enable
and still the viewports won't expand correctly. I assume there is no current fix for this. Thanks for help solving and really looking forward to the new build. :-)
7650.22 In reply to 7650.21
Hi Chipp,
Yeah there does not seem to be any way to configure things to fix the viewport maximizing thing for the current 3.0 MoI version. Somehow there is different behavior for hiding windows and the windows that are supposed to be hidden (for the other non-maximized viewports) are sticking around.
But it looks like I will be able to do some workarounds in MoI and roll out a new 3.1 version which will then solve it. Also you won't need to mess with disabling rootless either.
I think I'm on track for being able to get that out later today.
7650.23 In reply to 7650.22
Great! Don't worry about the snapshot screen stuff. I'll get it figured out. Thanks!
Show messages:  1-9  10-23
