Wrapping a texture mesh around a cylinder?
All  1  2-6
<< is this something possible to do with 3d?
Yes you can! :)
It's the Flow function as you find! The more interesting function of Moi! :)
Menu Transform / Deform / Flow
You must have 2 objects: Source - Target
And a Line / Curve / Surface as Transfert (here the rectangle)
Any Rotate - Size - Move of any Source, Target, Transfert depending of what result you want!
Have fun!
PS 2 videos (Sorry in French, but very Visual! :)
http://moiscript.weebly.com/enrobage-dobjet-v3.html
http://moiscript.weebly.com/enrobage-dun-tore-v3.html
EDITED: 1 Oct 2015 by PILOU
7647.3 In reply to 7647.1
Hi Misiu, yes like Pilou writes above you can use the Transform > Deform > Flow command to deform objects from a straight line onto a bent curve, or also from a flat base plane onto a curved surface.
Please take a look at the help file topic for Flow for an extended description of it:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
Also some links to previous forum discussions about Flow here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6746.5
7647.4
Thanks guys.
Getting a bit closer. I re-did the mesh for a much closer end result to what I was thinking. I did manage to get the flow command to work with some extra experimentation and wrapping around half a circle+mirroring the result.
Still some strange issue with edges overlapping, but hopefully I will figure out what is causing the surface alignment issue.
Size: 195.6 KB, Downloaded: 146 times, Dimensions: 718x687px
7647.5 In reply to 7647.4
Unwrap of a circle can produce a line of the proper length to use in the input. So either the line or a plane of the lines length is useful.
<< Still some strange issue with edges overlapping
For avoid that make first a single Source first without overlapping itself !
Show messages: All  1  2-6
