Multiple Fillets all at once?
All  1-3  4-6
7620.4 In reply to 7620.1
Hi Chipp - unfortunately there isn't currently any way set up to do a curve corner fillet on multiple curves all at once like that.
Fillet can take either one single curve for doing the corners, or 2 different curves for doing an AutoCAD style fillet between lines.
In the future I'd like to update this so that multiple selection like you're asking about could work.
7620.5 In reply to 7620.2
The reason I don't fillet first is that I want the same fillet on an array of differntly sized items. So the smallest 'square' with appropriate fillet is close to a circle, whereas the larger squares retain their square appearance with a small fillet on the corners.
7620.6 In reply to 7620.3
Great Pilou! Thanks :-)
Michael, thanks for the update. Looking forward to V4!
Show messages: All  1-3  4-6
