Voronoi Chair Tutorial
All  1-7  8-17
7596.8 In reply to 7596.6
No doubt it needs cushions. For what it's worth, I wanted to try and stretch the limits of some of the commands, like fillet, chamfer, boolean and offset. Worked pretty well except for the fact the chamfer didn't seem to take on all the edges; I needed to go back an individually chamfer select ones it missed.
Another image with colors on the 'inside' of the boolean. Interestingly, just providing a different color (style) for the inside surfaces of the solid didn't translate to Keyshot as separate parts when using NURBS (.3dm) but worked fine when using .obj. But, .obj didn't render near as nice as nurbs. So, I had to separate the solid into surfaces to get it to work with NURBS in KeyShot.
Another render showing the 'inside' colors (click to make larger):
7596.9 In reply to 7596.7
Interesting site! Thanks for sharing Frenchy :-)
7596.10
an amazing chair design and amazing skills chipp.
Thank you for sharing.
[Denis]
| Carrara Pro 8.5 | Cinema 4D Prime R15 | CorelDraw X6 | Moi 3D v2 | Lightwave 3D 11.6 |
| My work |
Maybe no use of Illustrator ? :)
7596.12 In reply to 7596.11
Yes, I saw your very creative use of Rebuild with no corner points in a previous thread and thought to try that. Great idea!
7596.13
It will be better to use DelCorners script ( one of the first my scripts, by the way :)
Voronoi, Select rectangle ->Planar, Select all -> Boolean merge, Delete lines, Select all -> Separate, Select edges -> Join -> Rebuild (tolerance 1), DelCorners
This is updated version of the script
EDITED: 7 Mar 2022 by SMIRNOV
Cool tricks! _Delcorners is excellent!
I don't use the same exactly way than your (not rebuild here) but use your _Delcorners and ExplodeMove of Michael for more possibilities of placement variations ;)
_Voronoi >> Kill Points >> > Select All>> Planar >> Trim >> Select Edges >> Copy Move them somewhere >> Join >> Delcorners>>ExplodeMove
EDITED: 9 Sep 2015 by PILOU
Works like a charm!
All fantasy are possible! :)
Voronoi, Delcorners, Flow
7596.16
7596.17
Show messages: All  1-7  8-17
