Variable Width Line Offset Command - fatT Lines
1-6
7-26
27-46
47-51
trzanko
28 Aug 2018 (47 of 51)
7594.47
In reply to
7594.16
Hi, how did you re import the subdivision model? I have yet to find a way to figure out how to import .obj's as simple as you make it sound.
T
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
28 Aug 2018 (48 of 51)
7594.48
In reply to
7594.47
As you export as OBJ from Moi
you can re-import the same File with ImportOBJ by Max Smirnov !
http://moi.maxsm.net/media/files/
(scroll)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
30 Oct 2024 (49 of 51)
7594.49
Can be useful for architecture or other things! :)
Fat Lines support now multicolors : curves must disconnected and in different Planes!
By Michael! ;)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/fatlines.v.0.7.2024.10.28.zip
If not you can make this little trick! ;)
Distribute your curves on Z
http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.17
Make Fat lines
Edit frame "Flat"
You can now Extrude your colored curves as you want!
And make any boolean operations!
All takes 3 seconds! ;)
EDITED: 30 Oct 2024 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
stefano (LIGHTWAVE)
28 Nov 2024 (50 of 51)
7594.50
In reply to
7594.49
hi pilou can you set the line widths to a specific width? e.g. 2mm or anything else a user may decide?
edit:
i presume that is setting the "larguer" slider shown in your earlier posts?
kindest...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
28 Nov 2024 (51 of 51)
7594.51
In reply to
7594.50
Of course yes you can input any width !
Here 10 unities on 2 separated straigt lines
If you have several widths make several sets of lines (curves)
You will have a different result if you take connected lines! (here a polyline of 2 segments)
EDITED: 28 Nov 2024 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
7-26
27-46
47-51
