Variable Width Line Offset Command - fatT Lines
 1-3  4-23  24-43  44-51
7594.4 In reply to 7594.3
This is more what I was thinking - if you select a large group of lines and try an offset to all MOI struggles with the output. You can see from the illustrator output that the offset is clean. What I mean from variable is able to change the width of the line. With this clean output it can be converted to a 3d object from which a lean nurbs model or mesh created. (Manual method to the grasshopper exoskeleton workflow)
Like the Voronoi generator another favourite of mine is the Taprats generator.
http://www.cgl.uwaterloo.ca/~csk/washington/taprats/applet.html
Its vector EPS outputs are of very high quality and great for creating repeat patterns.
7594.5 In reply to 7594.1
Hi Alex, try this simple script.
Unfortunatelly MoI's union factory doesn't work stable in some cases.
EDITED: 7 Mar 2022 by SMIRNOV
7594.6 In reply to 7594.5
thats excellent if somehow the Fillet and Chamfer can be worked into the script so that is controlled via that - makes it a really sharp chisel.
thanks again for the lightspeed.
7594.7 In reply to 7594.4
Hi Alex - I guess one thing I'm confused about is what part is "variable width" - that's what you mentioned in the title, but what you show in your example seems to be uniform width, not variable width?
Yes, the offset mechanism is not meant to be used for a case like that with "branching" in the line arrangement, it tries to form a single closed curve out of any lines you give it and if it instead ends up making some winding erratic path that will give strange results.
Unfortunately there is not currently a direct mechanism in the geometry library to handle a branched type offset like you are describing. It could be possible to create one but it would probably involve quite a bit of work and so it's not likely to happen anytime too soon.
Hopefully Max's script will help you in the meantime.
7594.8 In reply to 7594.5
Hi Max,
Had a play works well one small issue if last value on the slider was large and you have a large selection Moi hangs - would be good each time you initiate the script, it defaults to zero.
Here is a quick play random curve - array 3d - fatlines.
7594.9 In reply to 7594.8
""""""""""would be good each time you initiate the script, it defaults to zero.""""""""""
You can open FlatLines.htm and search for 50 and change that to zero if you want..
The slider is coded as a percentage, so you will only be able to slide to "10". But you can enter any exact number also, it will just default back to a 10 slide if you use the slider....
I usually handle these with 2 sets (or more) with a second named "FlatLines 50" or 100 etc..... If larger values are needed.
I set mine to min.1 mid 5 and max 50, default 0..... Because most of the stuff I work on will be smaller stuff. This gives me a .1 to 5 with half the slider and 5 to 50 with the other half.
EDITED: 6 Sep 2015 by BURRMAN
7594.10
Fixed default value
7594.11 In reply to 7594.10
Hi Max,
Had a play with the FatLine Script for some reason when I apply to a line sequence generated out of the Voronoi Script does not weld the items - they are all sitting on the same plane.
I have included test file.
thanks
Alex.
7594.12 In reply to 7594.11
Hi Alex,
There something wrong with Boolean Union factory. You need to deselect a border and run the script again.
7594.13 In reply to 7594.12
thanks AOK>
7594.14
Max,
I really like the Fat Lines script. Much appreciated. Is there anyway to add filleting to the corners of FatLines OR is there a way to select a bunch of EDGES and filet them all at once? It appears the Fillet command will on only work on one edge group at a time, so it becomes overly tedious to fillet each and every edge at the same time.
See my Voronoi video at 11:30 on how and why I like to use Illustrator to do mass fillets: https://youtu.be/agEvJcirfUE
Thanks again for a great set of Tools!
7594.15 In reply to 7594.1
Hey Alex, how did you do the subD version above? Is that in MoI. I thought it would only SubD solids made up entirely of quads?
7594.16 In reply to 7594.15
Hi Chip
YEP all in Moi - I exported the extruded shape from Inside Moi as OBJ traingles with division to lowest.
Re imported then ran the subD v6 Script.
Alex.
7594.17 In reply to 7594.16
Thanks Alex for getting back. Interesting technique!
Very tricky method!
Adopted!
PS In fact i had make the same here in the past :) http://moiscript.weebly.com/subdivision.html
I don't know why i had use the OBJ of SKetchup ??? :D
SKetchup -->obj By Tig for free version of Sketchup
Import OBJ --> Moi by Max Smirnov
Export OBJ from Moi (Quad + Triangle) :) By Michael
EDITED: 7 Sep 2015 by PILOU
7594.20
Hi guys,
Max, you create one great script after another, muchas gracias!
I was wondering if it would be possible to add an option to the Fat Lines script to taper each line (with options for start and/or end). That would be very useful for creating cartoony ink style lines.
Here's an example of how that would look:
http://metinseven.com — 3D modeling • design • images
7594.21 In reply to 7594.20
Hi Metin,
Could you show more examples? I have no ideas how this script should process straight lines or S-shaped (or overlaped) curves.
7594.22 In reply to 7594.21
Hi Max,
I've made a few more examples. The bottom example would be the result if only the ends of the lines would be tapered (as an option).
Maybe you could also include a taper amount, ranging from a gradual tapering along the complete length of the line(s) to only tapered outer ends.
I'd be very happy with this to ease stylized 2D drawing in MoI.
Metin
7594.23 In reply to 7594.22
Hi Metin
Well, it's not so easy as it looks. I'll think about it, but right now I can't see how to do it.
Show messages:  1-3  4-23  24-43  44-51
