A useful Kitbash technique for MoI3D
 1-10  11-30  31-50
7592.31
Hi Pilou
… Decal is a Normal map trick (with "HardOps" plugin when boolean needed)...
Tricky thing indeed for helping during Boolean operation in Polyworld! :)
7592.33
Wow. Vey interesting. Blender has really come a long way.
7592.34
Damn you Frenchy! I'm losing a whole day watching videos on Decal Machine, Hard Ops and Boxcutter for Blender. And I suspect I'm this far from jumping with both feet into Blender, UGH!
Every now and then a demo comes along that is a game changer, and I'm thinking the Hard Ops demo + Decal Machine is just that. It shows the power of parametrics as applied to low poly models. Amazing. I read a bit over on the modo forum wondering what they thought of it and I don't think they get it. They think is a weaker version of mesh fusion, which it's clearly not. It's actually much more, plus they have a full kitbashing workflow built into it plus some of the best kitbash models included.
Decal machine needs to work with Unity and Unreal, which they say is a version away.
I guess the big question is, can I successfully work in Blender without going nuts over the non standard GUI? Don't know until you try...
FWIW, I'm also considering switching from KeyShot to Unity for final renders, as Octane is releasing a free version for Unity this quarter. Things are moving fast!
I need to learn more about Blender.
Michael, you should take a peek at how they implement parametrics. Couple of points:
1. They don't appear to create a history and only apply them in the order that makes most sense. In particular, they have a concept called *sharpening* (I think), which applies a small user resizable bevel/fillet to all edges on an object. It can only go as large as programmatically possible. I assume it's a post process which happens after large solid/ surface changes are made. My guess it works best in MoI case with solids.
2. It would be interesting to better understand what your users are now using Moi for. More and more, I'm seeing high detail box designs and sci fi concepts being built in MoI. Mostly people talking about that on other forums, but it is interesting to note -- and a flexible workflow like the Hard Ops one would certainly make sense for those users.
3. Hard Ops is a *mode*-- and I know you're not fond of modes. Still, this type of limited auto-parametrics could be a major differentiator for you in the future. I know, first get 4.0 out!
https://youtu.be/4Rlu8HS5EOM
EDITED: 27 May 2017 by CHIPPWALTERS
Blender is a monster : when you see Youtube videos of Gleb or Andrew Price
https://www.youtube.com/user/GlebAlexandrov
https://www.youtube.com/user/AndrewPPrice/featured
that seems very easy...but you must have some years of use it! :)
I know how it works but...
Personnaly I never dig on...not genitically modified for this!
So...i see the videos for the pleasure of the eyes! :^)
PS we have a French Blender Guru Pitiwazu :)
https://www.youtube.com/channel/UCaA3_WSE5A0H6YrS1SDfAQw/videos
EDITED: 27 May 2017 by PILOU
7592.36 In reply to 7592.34
Hi Chipp and Pilou!
@Chipp "...Damn you Frenchy! I'm losing a whole day watching videos on Decal Machine, Hard Ops and Boxcutter for Blender. And I suspect I'm this far from jumping with both feet into Blender, UGH!..."
During the last month I too have begun to get a closer look to the almost (for me) "unknown" Blender.
Its super complex and strange UI always kept me away from it.
But now I have to say that after spending some time with some very interesting tutorial,
I'm seriously evaluating the opportunity to include it into my current 3d pipeline.
And the upcoming version 2.8 shows real promise.
I think that it could be an excellent companion for the other software that I'm currently learning : Unreal Engine 4.
(I preferred UE4 over Unity)
See you.
7592.37 In reply to 7592.34
Hi Chipp, I watched a few minutes of the video and it definitely looks interesting. I'm not sure how much of it is very applicable to MoI though, the focus in MoI is on construction driven from 2D profile curves which is pretty different than what they're focusing on there.
Well it's a quite diverse group of users, everything from students doing their first 3D design work for 3D printing all the way to people doing sci-fi graphics work like you're describing. Some people are much more likely to publicize their work than others, so it's easy to get a kind of lopsided view of the user base if you only focus in on the most highly publicized stuff.
One big thing is that MoI is very focused on being easy to learn and not very complex. It may be hard to reconcile that with a workflow like that which has a lot of special modes in it.
Having said that though, I do want to put in some work on other kinds of workflows in MoI in the future. But it will also be a priority to not ruin the "easy to learn" aspect along the way though.
It would probably work best if something like that was implemented in MoI as a custom extension rather than being built in, just like they've done there. A custom extension is more free to do complex and specifically targeted things than stock tools which have to be more focused on a wide variety of use cases.
7592.38
All good points Michael.
Perhaps there's a middle ground.
Here's an idea:
1. Currently, beginner and advanced users have trouble filleting, especially a large fillet after a model already has a small fillet.
2. There is a large requirement on many (but not 3D printed) models to have some sort of small chamfer/fillet on all edges. Let's call this auto-filleting.
3. Perhaps there can be a way to automate this process in a way which is simple. Set an auto-fillet property for a NURBS solid object (doesn't work on non-solids). Set the auto-fillet/chamfer radius to a number which the current NURBS object can handle.
4. As one starts modifying the solid, the auto-fillet can continue to be added at the end of the editing process. If the fillet is programatically impossible, then it uses a smaller number and tries again. Perhaps this runs in it's own thread.
5. Perhaps one can override the auto-fillet on a case-by-case, edge-by-edge basis, with the understanding it may revert to a smaller number if further edits create an impossible to fillet model.
6. Allow one to "BAKE" the object at some point and no further auto-filleting is possible.
Something like this would make it easier to model because you would know quickly whether or not you wrecked the opportunity to add a 'final' fillet. And furthermore, it would also pop a red flag (no auto-filleting possible!) when something you did created surfaces from a solid object.
Just my 2 cents...
7592.39 In reply to 7592.38
Hi chippwalters
Or
7. use Octane render : as since v3.5 each octane material have the "Rounded edges radius" parameter ( a shading effect ) no more need to fillet edges.
7592.40 In reply to 7592.38
Hi Chipp, it's an interesting idea and sounds like a good possibility for the future. Things running on their own thread greatly increases the difficulty of the coding though so it might involve quite a lot of work to make it function smoothly. Fillets in NURBS involves a lot more complex calculations than in polygons so the threaded approach might be a requirement to avoid lots of waiting before being able to do more stuff. Also I'm not sure if it makes sense to put effort into increasing fillet robustness first before attempting that.
7592.41 In reply to 7592.39
If Octane's round edge shader is as poor as KeyShot's, then I would prefer real geometry.
KeyShot's shader struggles mightily on any but the smallest of settings, especially with CAD models converted to poly's.
7592.42
Michael (and all),
https://youtu.be/jnTZLh4Na0c
Please consider this video. Forget for a moment that it's focused on decals. What strikes me the most about this video is the relationship between the modeling and then the rendering. Design details which I thought too coarse in the model view, looked correct in the rendering.
I have seen this same phenomena in my own designs when working both in SketchUp and MoI.
I believe this iterative affordance of modeling and rendering quickly is a huge assist for designers and artists. I hope this helps provide further encouragement for the addition of a photoreal rendering or ambient occlusion addition to MoI.
7592.43 In reply to 7592.38
Hello,
Maybe some sort of post-process micro beveling that works at the mesh level could work better than a full auto nurbs fillet idea. (might be part of the mesher ?)
I kinda like the rounded edges at render time, it works very well for stills or normal map baking, and I never had problems with it in Modo and Clarisse.
However, people seems to extract normal maps using SubstanceDesigner now, and last time I checked, there wasn't any round shader available for the baking (but there are so post trick possible once the normal is extracted).
I end up to create a little process in Houdini, that 'voxelize' / decimate / export Moi models, the result was super crisp.
Talking about hard surfacing, this video get lot's a attention lately from non CAD users ^^
https://www.youtube.com/watch?v=ctI-tMc8U7M
Spaceclaim for gun concept :
https://www.artstation.com/artwork/3DJdB
EDITED: 28 May 2017 by PAQ
7592.44 In reply to 7592.43
Widget Kitbash Library link seems to be broken anyone still has it?
7592.45 In reply to 7592.44
Maybe here ... http://moiscript.weebly.com/kitbash.html and scroll...
EDITED: 15 May 2019 by PILOU
7592.46
https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/markdown/MoiObjLibDontMove/mdwiki.html#!index.md
Sorry, the images and links are down right now (ever since Dropbox quit hosting files). You might be better off with Pilou's version.
7592.47 In reply to 7592.46
Cool: i was affraid about copyright trouble! :)
7592.48
***NEVER FOR YOU*** Pilou. You do so much for this community! :-)
7592.49 In reply to 7592.48
I agree!!
Pilou: the N. 1 Ambassador of the 3d world!!!
7592.50
Hello!
I'm new to MoI. I had some fun with these kitbash objects :). Thanks Chipp for making them and thanks pilou for your website!
I found that it will be even easier to use these with Flow. Just a few clicks and you can project them onto your geometry. Using Flow these will even work on curved surfaces.
I added a Flow Surface style to the kitbash item.
And you can project multiple kitbash items together
For curved surfaces you might want to do it in 2 steps. For example in this case I don't want to deform the fan blades and the cutter geometry so I projected them with Rigid option enabled.
Show messages:  1-10  11-30  31-50
