Insetting surfaces to create solids tutorial
All  1-11  12-17
7585.12
Another Inset Solids Tutorial with a few more "tricky stuff" (as Frenchy would say!).
Tricky easy stuff indeed! :)
7585.14
And even easier way to accomplish #2:
7585.15
Nice ans imple Chipp.
thank you.
[Denis]
| Carrara Pro 8.5 | Cinema 4D Prime R15 | CorelDraw X6 | Moi 3D v2 | Lightwave 3D 11.6 |
| My work |
A little variation! (maybe less complex - Solid at the end are not separated here) ;)
As you see with the vertical lines Inset is moved on the left from its dimensions so draw your Arc Circle in consequence! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/variation.3dm
EDITED: 27 May 2017 by PILOU
7585.17 In reply to 7585.16
Thanks for sharing Frenchy!
Show messages: All  1-11  12-17
