Object Spatial Array COMMAND WISHLIST
 1-7  8-27  28-31
7574.8 In reply to 7574.7
Hi Alex,
> In MOI saving layers as OBJECT Groups is not an option, currently I complete model in MOI then
> export in RHINO so that I can save with layers as OBJECT GROUPS this allows import into Zbrush
> with objects as subtools for various operations in ZBRUSH.
There's a setting in moi.ini that probably should help with this - go to Options > General > "Edit .ini file" button. Then inside moi.ini find the section for [OBJ Export] and set WriteStylesAsGroups=y , like this:
[OBJ Export]
With that set, the group name for an object will come from the object's style name rather than the object name.
> Perhaps another comment is a having a central repository command library - linux style
> where all the various scripts can live in there various development stages making easier
> to find rather than digging through blogs or forums.
That's definitely something I want to add - I'd like to have an online library of scripts and some kind of browser that you can use in MoI to look through them and install them. It's just something I haven't had time to work on quite yet.
7574.9 In reply to 7574.8
Thanks for the tips - one more thing to add perhaps in the future centrally managed Command Library is adding a text file outlining use for the specific command as some of the commands are probably not used that often and having a readme or help outlining the usage flow could be really helpful.
regards
Alex.
7574.10
Array3D v0.4 early beta
More features I will implement later. Maybe :) In fact I'm very disappointed with the overall performance of this script.
Be careful while using this script, it can cause MoI to hang.
EDITED: 7 Mar 2022 by SMIRNOV
7574.11 In reply to 7574.9
Hi Alex,
Yup, I'd like to have something like that as part of the plug-in browser mechanism.
It will take a lot of work to make that work well and so I'm not sure exactly when it will happen though.
EDITED: 30 Aug 2015 by PILOU
7574.13 In reply to 7574.10
Hi Max,
Absolutely brilliant and in keeping with the MOI simple workflow a fantastic piece of code. For a v0.4 early beta pretty much there.
Here is a 1 minute concept to model application.
You deserve a Vodka or Beer after that effort.
Awesome! Thanks
Alex
EDITED: 26 Jan 2020 by ALEXPOLO
7574.14 In reply to 7574.10
I immediately did archi stuff with it. Right on Max!
In same order of idea you have yet Script Array and Line Array and Scale Array ... ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.1
7574.16
v 0.5
[added] pointpicker support (click -> change target point, ctrl+click -> change base point)
[added] randomize function (double click on title "Array3D")
7574.17 In reply to 7574.16
French version adapted! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
No time to use it but absolutly cool! Bravo!
I believe you must add in your help text : Click or Ctrl +Click in the "empty space" ! ;)
7574.18 In reply to 7574.16
Great stuff Max. Thanks!!!!
7574.19
Version 0.6
Performance boost ~2x
7574.20 In reply to 7574.19
French version updated! ;)
Always fun :)
7574.21 In reply to 7574.4
Hum, make it and I will be yours for ever lol..... ha ha No kidding I use a lot of repetitive actions and the one made in Zbrush is really powerful !
7574.22
boblog
Sorry, in the nearest future this script can't get even close to Zbrush performance.
The main problem which stops me - the lack of instancing engine in MoI. This script makes thousands copies of the object, instead of making instances of one object. It consumes a lot of processor resources and memory and dramatically lowers performance of the script.
AFAIK, Michael have plans to implement support of instances in future versions of MoI.
Yesterday I spent couple of hours to increase script performance.
v.0.5 used 4 factories:
1 x orient (to place an object to a new point and than orient it)
3 x scale1d (for X, Y, Z rescaling)
v.0.6 uses only 2 factores
I've found that I can adjust xaxis and yaxis parameters of the target CoordinateFrame to process move/orient/X-scale/Y-scale using only one factory. :)
Unfortunatelly, zaxis parameter is read only, so I need to use second factory (scale1d) to correct Z-size.
Michael, please make it writeable in the next version.
AlexPolo
Thank you ;) I'll buy a box of vodka! The next version of the script will generate even more twisted and scattered structures :))
chippwalters
BurrMan
Thank you! :)
7574.23
v.0.7 will be tomorrow ;)
[added] X/Y-mirror mode
Appetizing! :)
7574.25 In reply to 7574.24
Hi MAX,
The script is evolving at lightspeed - what about putting in an auto FIBONACCI sequencer.
Playing with the controls and an extra point for rotational control gets close to home anyway.
Awesome work!
EDITED: 3 Jul 2022 by ALEXPOLO
7574.26
v.0.7
Hi Alex,
In the next version I'll add "Align to path" function. I'll think about fibonacci spiral then.
Show messages:  1-7  8-27  28-31
