Object Spatial Array COMMAND WISHLIST
 1-12  13-31
7574.13 In reply to 7574.10
Hi Max,
Absolutely brilliant and in keeping with the MOI simple workflow a fantastic piece of code. For a v0.4 early beta pretty much there.
Here is a 1 minute concept to model application.
You deserve a Vodka or Beer after that effort.
Awesome! Thanks
Alex
EDITED: 26 Jan 2020 by ALEXPOLO
7574.14 In reply to 7574.10
I immediately did archi stuff with it. Right on Max!
In same order of idea you have yet Script Array and Line Array and Scale Array ... ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.1
7574.16
v 0.5
[added] pointpicker support (click -> change target point, ctrl+click -> change base point)
[added] randomize function (double click on title "Array3D")
EDITED: 7 Mar 2022 by SMIRNOV
7574.17 In reply to 7574.16
French version adapted! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
No time to use it but absolutly cool! Bravo!
I believe you must add in your help text : Click or Ctrl +Click in the "empty space" ! ;)
7574.18 In reply to 7574.16
Great stuff Max. Thanks!!!!
7574.19
Version 0.6
Performance boost ~2x
7574.20 In reply to 7574.19
French version updated! ;)
Always fun :)
7574.21 In reply to 7574.4
Hum, make it and I will be yours for ever lol..... ha ha No kidding I use a lot of repetitive actions and the one made in Zbrush is really powerful !
7574.22
boblog
Sorry, in the nearest future this script can't get even close to Zbrush performance.
The main problem which stops me - the lack of instancing engine in MoI. This script makes thousands copies of the object, instead of making instances of one object. It consumes a lot of processor resources and memory and dramatically lowers performance of the script.
AFAIK, Michael have plans to implement support of instances in future versions of MoI.
Yesterday I spent couple of hours to increase script performance.
v.0.5 used 4 factories:
1 x orient (to place an object to a new point and than orient it)
3 x scale1d (for X, Y, Z rescaling)
v.0.6 uses only 2 factores
I've found that I can adjust xaxis and yaxis parameters of the target CoordinateFrame to process move/orient/X-scale/Y-scale using only one factory. :)
Unfortunatelly, zaxis parameter is read only, so I need to use second factory (scale1d) to correct Z-size.
Michael, please make it writeable in the next version.
AlexPolo
Thank you ;) I'll buy a box of vodka! The next version of the script will generate even more twisted and scattered structures :))
chippwalters
BurrMan
Thank you! :)
7574.23
v.0.7 will be tomorrow ;)
[added] X/Y-mirror mode
Appetizing! :)
7574.25 In reply to 7574.24
Hi MAX,
The script is evolving at lightspeed - what about putting in an auto FIBONACCI sequencer.
Playing with the controls and an extra point for rotational control gets close to home anyway.
Awesome work!
EDITED: 3 Jul 2022 by ALEXPOLO
7574.26
v.0.7
Hi Alex,
In the next version I'll add "Align to path" function. I'll think about fibonacci spiral then.
7574.28 In reply to 7574.26
Hi Max,
The align to path is an excellent idea that will give huge functionality in controlling the array over a surface or another object - this will take it past Zbrush in that respect.
Keep moving at lightspeed!
Thanks for your great work - the mirror function is great also.
Alex.
7574.29 In reply to 7574.28
Hi Max,
Can see how busy you have been with so many of the scripts in the forum any further thoughts on the Align to Path function for this scrip
7574.30 In reply to 7574.29
Hi Alex
I have started to write next version of this script few weeks ago. But something went wrong :) I was not satisfied with the results. So I decided to take a break and switch to another script ( subd ).
Now I have rested enough, so I will continue developing of the script this weekend or maybe next week.
7574.31 In reply to 7574.30
Max, you are a machine!! Man, I was impressed just reading this post. What a great community MOI has.
Dave S
Show messages:  1-12  13-31
