Heightmap [script]
 1-13  14-33  34-53  54-67
7547.54 In reply to 7547.53
Hi Finema,
no, I didn't change anything
7547.55
Today I wrote RasterImage script based on heightmap (inspired by Paper.js examples)
http://moi.maxsm.net/files/scripts/RasterImage.v.0.5.2018.02.25(MoI.v4).zip
EDITED: 7 Mar 2022 by SMIRNOV
7547.56 In reply to 7547.55
Amazing work Max!
By the way, if you squint your eyes while looking at Max's image above you'll be amazed how it comes to life!
Cool!
No possibility to put colors from image ?
My Moi French Site My Gallery
French Version of HeightMap ;)
http://moiscript.weebly.com/heightmap.html
a color version for you, as .pdf which you can load into Affinity Designer and then make a big
poster from it. :-)
EDITED: 5 Nov 2019 by STEFAN
7547.60 In reply to 7547.59
Cool !
but the PDF has no color inside Moi! ;)
I know, maybe worth to ask for a feature request in v4...
7547.62 In reply to 7547.61
Yes :)
Here a random one! :)
7547.63 In reply to 7547.52
Hello Max,
I hesitate to ask anything of you as you have been so very generous.
However, I continue to wonder if it might be possible to generate Heightmaps from within MOI.
This would augment your wonderful script by allowing z coordinates from existing MOI surfaces to be altered within image processers (i.e. Photoshop) and vice versa.
The ability to iteratively import & export Heightmaps would broaden the range of possibilities exponentially by applying the power of each toolset to the other.
Best regards from your most grateful and ardent fan,
-- Mindset
7547.64 In reply to 7547.63
Hi Mindset, you could use the Transform > Deform > Flow command in MoI to apply a heightmap over an existing surface.
Draw a plane at the z = 0 level of the heightmap, then select the heightmap to be the object to deform, run Transform > Deform > Flow, then when it asks for the base surface select your z = 0 plane, and for the target surface select the existing surface.
There's more information about Flow here:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
7547.65 In reply to 7547.64
Yes, thank you Michael... at the risk of redundancy, I reiterate that Moi3D has given me more joy than any other intangible product since the Beatles; and for a baby-boomer that is saying a lot!
All the very sophisticated contributions bestowed by our extraordinarily vibrant community of users are also particularly significant.
However, there are potentially limitless possibilities that the iteratively import & export of Heightmaps could allow.
An example might be the inclusion of gradients in various blending modes clipped into layers that could influence the resulting surface in unimaginable ways. It is doubtful that anyone could predict the artful outcomes that our community might come up with through such means.
In any case, there is a particular heightmap challenge for which I am willing to pay some reasonable amount for a workable solution. Given a contoured, vertically symmetric, pseudo-cylindrical curvaceous surface... it is desirable to have a heighmap relative to a central vertical axis for which the output width would correspond to the varying surface circumferences. If possible, it would be preferable that the solution find the center point for each segment of calculation, rather than measuring surface distance from some predetermined linear axis. It would be acceptable to have the 'front' and 'back' 180° output separately. If someone is interested in undertaking this challenge, please message me.
I remain extremely grateful.
Many thanks,
-- Mindset
P.S.
A special salute to Max.
7547.66 In reply to 7547.65
That sound quite a bit like unwrapping a cylinder...
7547.67 In reply to 7547.66
@bemfarmer [That sound quite a bit like unwrapping a cylinder...]
Yes, it does need to be "unwrapped".
The result should be a displacement map rather than a transformed surface.
Obviously we are not considering a true cylinder which, by definition, would always be equidistant from its central axis (of course).
EDITED: 26 Feb 2018 by IGNITER
Show messages:  1-13  14-33  34-53  54-67
