Array details
All  1-5  6-10
7521.6
Hello,
It might be worth it to take a look at benfarmers excellent scripts, the nest alarm looks like a Fibonacci sequence.
7521.7 In reply to 7521.1
You can also get different types of radial deformation effects by using Flow on a sweep of a line around a circle to make a base surface. Then edit the line by adding control point and changing the spacing or positions and do a second sweep to make a target surface for the flow:
These scripts by Max Smirnov can help!
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
Make boolean diff with Cylinder and complex volumes!
Sorry i can't help for the moment, my hard disk is burned! :(
EDITED: 30 Jul 2015 by PILOU
7521.9
WOW!! Thanks everyone! Great stuff and plenty to work with here. ***MUCH APPRECIATED***
7521.10 In reply to 7521.6
I think OSTexo is correct.
The NEST grill seems to be based on the sunflower.
Some Fibonacci sunflower math here:
http://momath.org/home/fibonacci-numbers-of-sunflower-seed-spirals/
Size: 586.7 KB, Downloaded: 74 times, Dimensions: 1024x768px
Show messages: All  1-5  6-10
