Array details
All  1-4  5-10
7521.5 In reply to 7521.1
Another way that might be interesting to you is to do a circular array of some graduated sizes, then rotate every other radial set by a half step. After you figure out how many copies you want to make, undo the array and then select every other circle, run Transform > Rotate, click the array center point and then type in 360/numcopies/2 to get those ones rotate a half step and then repeat the array.
So for instance here I arranged a graduated set of circles each 80% shrunk in size from the next (click the Size entry in the properties panel and then type *0.8 to scale the existing radius by 80%), then arrange them a constant distance away from each other by putting in a line and moving the line on to a circle's quad point and drag the next circle by its quad point snapping on to the end of the line, then drag the line over again to repeat.
Then since I decided to make 32 copies, I select every other circle, run Transform > Rotate, click the center point and then for the rotation angle type in 360/32/2, then repeat the circular array (3DM file attached):
Hope this gives you some ideas to play with!
7521.6
Hello,
It might be worth it to take a look at benfarmers excellent scripts, the nest alarm looks like a Fibonacci sequence.
7521.7 In reply to 7521.1
You can also get different types of radial deformation effects by using Flow on a sweep of a line around a circle to make a base surface. Then edit the line by adding control point and changing the spacing or positions and do a second sweep to make a target surface for the flow:
These scripts by Max Smirnov can help!
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
Make boolean diff with Cylinder and complex volumes!
Sorry i can't help for the moment, my hard disk is burned! :(
EDITED: 30 Jul 2015 by PILOU
7521.9
WOW!! Thanks everyone! Great stuff and plenty to work with here. ***MUCH APPRECIATED***
7521.10 In reply to 7521.6
I think OSTexo is correct.
The NEST grill seems to be based on the sunflower.
Some Fibonacci sunflower math here:
http://momath.org/home/fibonacci-numbers-of-sunflower-seed-spirals/
Size: 586.7 KB, Downloaded: 74 times, Dimensions: 1024x768px
Show messages: All  1-4  5-10
