Handle connection
 1-19  20-26
7414.20 In reply to 7414.19
Hi
Why don't you use a boolean Union (screenshot1) and a fillet. I think it's the easy way.
EDITED: 9 May 2020 by FINEMA
7414.21 In reply to 7414.20
I tried Boolean Union and a fillet, but the surface is not absolutely smooth.
I would like surface connection as solids wearing stockings.
7414.22 In reply to 7414.21
Hi Piter, re: IGES problem - somehow Pro/E does not like how that one surface is trimmed. The best thing to try is do a new export using STEP file format instead and see if that works better.
You should use a G2 blend instead of a circular fillet then. As far as I can tell, you had the kind of result you are looking for in this previous message here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7414.12
All those things you are complaining about in that message are just visual display artifacts, not anything wrong with your surfaces themselves.
Please read my reply here which explains all that in detail:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7414.15
If you would like you can post your model with the G2 blend in it and I will show you what it looks like with a finely diced up mesh for display so you can see that those visual imperfections are just display artifacts and not really something to worry so much about.
7414.23 In reply to 7414.22
A lot thanks for comments! I study it and tried made so.
I cut the tube and the egg different curves and blend G2 0,5.
Exprot to STL max mesh and open in Blender
Export to STP and open in PROE
Non-cutting tube and egg in 3dm attached.
What I made wrong?
And very big question about export to PROE, is there any solution this problem, plagin or other???
7414.24 In reply to 7414.23
Hi Piter,
> What I made wrong?
I'm not sure - can you please post the 3DM file that you are trying to export ? The finished file I mean, not the earlier version of it. I will try it in a few other programs and see if I can see what they might be complaining about.
I'm not all that familiar with Pro/E so I don't really have a lot of advice. What specific version of Pro/E are you using?
7414.25 In reply to 7414.23
For smoothness it will probably help if you give the blend a bit wider space to work with, and also slice off a larger portion of the ellipsoid so that you don't have so much of it curving inwards which will then make the blend continue to curve inwards as well.
I've attached a smooth version here, if you export to a mesh format such as .obj and use the following settings you can see that it's very smooth, dense meshing settings like this will get rid of the display artifacts that you were worried about earlier:
7414.26 In reply to 7414.23
A couple of other things you can try for your Pro/E problem is to try running "ShrinkTrimmedSrf" on your object before you export and see if that helps:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#shrinktrimmedsrf
And the other thing that you could try is to import your model into a different CAD program like ViaCAD for example and then export it back out again and see if Pro/E likes the file generated by ViaCAD better. You can get ViaCAD here: http://www.punchcad.com/p-27-punch-viacad-2d3d-v9.aspx
Those are the other things that I'd probably try.
But if you can post the specific file that you are having difficulty with I can take a look and try to see what it might not like in it.
Show messages:  1-19  20-26
