Dimension tool (as in sketchup)
 1-8  9-28  29-48  49-68  69-88  …  129-138
7403.29
Hi Max,
arrow type is nice feature.
...as Frenchy imply, it would be very useful to have two additional checkboxes (same as Unit) "prefix" and "suffix" with text field for pasting symbols or additional text in front and behind of dimensions.
... and Arc drawing with angle value would be absolutely fantastic :-)
Excellent job, thank you.
Mik
7403.30
A well made script. Quite useful while we wait for a proper dimension element.
M.
Someone ask text before the dimension, also text in replacement of the dimension! (here text is after)
You can make that but...
EDITED: 30 Jun 2015 by PILOU
7403.32
Michael
>obj.setHitTest( false );
Yes! That's exactly what I needed. Thank you! :)
Mik
I've made some changes in the new version ;)
v0.6
Snapping disabled for dimension lines (now script works exacly as planned)
Added more hidden features:
Prefix can be setted by using split symbol | in the units field. Example: R|mm -> R 15.1 mm
Special for you. :) Add * in the beginning. Example: *3/4 de pieds d'alouette!
EDITED: 7 Mar 2022 by SMIRNOV
7403.33 In reply to 7403.32
Max, brilliant!! Thanks again for the tweaks to the already awesome! script.
Cheers.
7403.34
Hi Max,
it works perfectly.
Many thanks!
Mik
@Max
Excellent! Bravo!
French Version Updated! http://moiscript.weebly.com/cotations.html
7403.36 In reply to 7403.3
Michael,
Thank you for putting this on your V4 list. Probably not the most fun thing to work on but but man will it put a spin on MOI.
Terry
7403.37
Great tool !
many thanks Max !
Message 7403.38 deleted 1 Jul 2015 by MIKULAS
7403.39
Hi Max,
I allowed myself to add new arrow type 4, which can be useful for various description in drafts.
Kind regards,
Mik
7403.40 In reply to 7403.39
Neat add!
French Version UpDated http://moiscript.weebly.com/cotations.html
EDITED: 1 Jul 2015 by PILOU
7403.41
This is so helpful. Thanks so much Max for your time.Theses scripts really help fill some missing features without changing the program.
7403.42
...and twin of type 4 -> type 5 :-)
7403.43 In reply to 7403.42
Does it not possible to input a test inside the code for have only a Type 4 ?
Pseudo Code : When 180° > Arrow Angle > 360° reverse Position Text ...
7403.44
it's question for MAX, I have no experiences with script writing unfortunately. I've only analysed Max's script and analogically added new arrow types.
I've only noticed that arrows are created as polylines in Cartesian coordinate system and then it makes surface from polyline.
Position of text is done by vector of direction probably when the arrow line is created (from left to right and vice versa).
BTW Type 5 is can be used for radius measurement as well. In "unit" text box it has to be paste " R| "
Mik
7403.45
Great script, Max, very useful.
7403.46
Max should get some sort of "USER OF THE DECADE" award for MoI. Great job!!!
7403.47 In reply to 7403.43
Frenchy Pilou
Now it looks better :)
7403.48 In reply to 7403.47
I am confident! :)
Seems cool!
French version
EDITED: 3 Jul 2015 by PILOU
Show messages:  1-8  9-28  29-48  49-68  69-88  89-108  …  129-138
