Dimension tool (as in sketchup)
 1-12  …  73-92  93-112  113-132  133-138
7403.113 In reply to 7403.112
Hi JL82,
> the script is not working for me. I got the script error.
From the error it looks like you are running MoI version 2, and I think the script requires MoI version 3 in order to run properly.
7403.114 In reply to 7403.113
Yes, I have version 2.
7403.115 In reply to 7403.114
Hello everybody.
The distance, the red arrow can be changed? Between the dimension line and digits?
Through editing files "_Dimensions.htm" or "_Dimensions.js"?
7403.116 In reply to 7403.115
I am affraid not yet but just select and move it! ;)
7403.117 In reply to 7403.115
Hi GonzoRus,
Yes it's possible to change that spacing by editing the _Dimensions.htm file.
Using the latest version Dimensions.v.1.0.2015.09.14.zip which you can get from here: http://moi.maxsm.net/media/files/ , you would want to modify line #135 which sets the placement of the text.
135:     textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/3)/2, 0);
You would want to add something to the 2nd parameter to frame.evaluate(), like this for example (see the bold text for the + 1 that is added):
135:     textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/3)/2 + 1, 0);
7403.118 In reply to 7403.117
Cool ! Will be added to the manual!
Done! http://moiscript.weebly.com/cotations.html :)
EDITED: 3 Apr 2016 by PILOU
7403.119
Hi guys :)
This +1 method doesn't work correct in some cases.
It will be better to use the following line:
textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/2)/2, 0);
or
textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize/1)/2, 0);
or
textframe.origin = frame.evaluate(textShift, (1-2*(angle>=180))*(lineWidth+textSize*3)/2, 0);
7403.120 In reply to 7403.119
Maybe input this on the Dimension Menu will be very fine! ;)
7403.121 In reply to 7403.120
"Maybe input this on the Dimension Menu will be very fine! ;)"
YES!!! it would be amazing!
7403.122 In reply to 7403.121
Changed line 135
The distance from the dimension line has increased.
BUT! The angles are displayed incorrectly.
7403.123 In reply to 7403.5
Hi
Will the script work on Mac - and how?
7403.124 In reply to 7403.123
Hi Karl, yes the dimension script will work on the Mac version as well.
You can download the latest version of the script from Max's site here: http://moi.maxsm.net/media/files/ the one you want is named Dimensions.v.1.0.2015.09.14.zip
Then for installation instructions please refer to FAQ #1, how do I install a plug-in script? .
7403.125
Hi All,
I have read this thread with some interest as it may be feasible for me to somehow export MoI3D files with dimensions. I also noticed that Michael had/have this as a potential part of a V4 release ...
To this end: Is there any news on whether or not this will be part of a V4 release - and if so when is the V4 release due?
Have a good day ;-)
Jesper
7403.126 In reply to 7403.125
Hi Jesper, I can't really promise 100% that it will be in v4 but it is one of the priorities that I want to work on. I won't really know how it will go though until I've been able to work on it some.
The V4 beta test period just started a few weeks ago, and could last anywhere between 4 to 9 months before the v4 final version is ready.
Right now the only things I can say for sure that will be in v4 are that it will be 64-bit and have a native Mac version.
Seems Dimension by Max Smirnov works also with the Beta of the 27 November 2017!
7403.128
Hello,
It dosn“t work with V4 beta (18.11.). Invalid function argument 1 , line 1
Only for me?
7403.129 In reply to 7403.126
Hi Michael - as always thanks for your prompt and helpful reply ;-) ... I will look out for what happens with the v4 as it progresses ... Have a good weekend when you get to that ... Jesper
7403.130 In reply to 7403.128
HI
I also have a problem when :
1 - i call this fonction (TypeError...)
2 - i select an objet and call this fonction (Invalid index ...)
3 - i would like th draw a dimension ( tab is empty , color line is white)
chri
7403.131
Hi
A dumb question.
Is there a way to get Max's dimensions to display feet/inches/fractions?
thanks,
eric
7403.132 In reply to 7403.131
hi eric
Please take a look to the previous post 7403.93
chri
Show messages:  1-12  …  53-72  73-92  93-112  113-132  133-138
