Hatch Fill
 1-18  19-37
7279.19 In reply to 7279.18
Hi Martin, it's because your <moi:DistanceInput> control is not closed. V3 and V4 differ on how malformed HTML is processed, V3 would scan ahead and see there is no end tag found and then close off the tag. V4 I believe adheres to what is supposed to happen which is that it puts the content after your unclosed tag as children of it and doesn't close it off automatically at its origin point.
You can fix it and make it work in both V3 and V4 by closing that tag like this:
<moi:DistanceInput id="offset" value="2"/>
7279.20 In reply to 7279.19
Lines 60 and 61 of .js are missing semicolons.
Runs on MoI4beta11_28_17 in top view, after making the 3 changes: / ; and ;
As a general question, is there some kind of 3rd party debugger or interpreter checker program?
7279.21 In reply to 7279.20
Hi Brian, I haven't tried it myself but you might look at JSLint for JavaScript files. A checker for .htm files may be more problematic because it may say the custom moi: elements aren't standard and it also won't like that moi.css is implicitly added to every file.
re: semicolons - I believe semi-colons at the end of lines are officially optional in JavaScript so it should still run without those but it is good practice to have them.
7279.22 In reply to 7279.21
Thank you Michael.
I'll try JSLint some time
EDITED: 3 Dec 2017 by BEMFARMER
7279.23
Thank you Michael and Brian, I will update the script.
-Martin
Edit: I attached an updated version to post 7279.9
EDITED: 4 Dec 2017 by MARTIN3D
7279.24
Hi
Hatchit script works fine
i have find a trick to change the direction of the hatching
is it possible to add a parameter in the script to input the direction ?
Chri
Size: 33.7 KB, Downloaded: 83 times, Dimensions: 886x522px
7279.25
NEW EXAMPLE
Chri
Size: 210.1 KB, Downloaded: 65 times, Dimensions: 1346x875px
7279.26 In reply to 7279.24
Hi Chri, try this version I've modded Martin's cool script so it has a rotation parameter added.
7279.27
Hi Michael
Exactly what we need .
your are incredible.
Have a good day
Size: 89.7 KB, Downloaded: 77 times, Dimensions: 684x457px
French version in no time! :)
Done : https://moiscript.weebly.com/hachures.html
EDITED: 27 Feb 2021 by PILOU
Seems working only on the "top view" faces's object! ?
7279.30 In reply to 7279.29
Yes, the closed shapes must be drawn in the top view and if you want to hatch several closed curves at once they must be all on the same Z plane.
HINT
You can hide all hatch lines In the Scene browser under Objects.
Or you can select and delete or color all hatch lines.
Thank you Michael for modding the script!
-Martin
7279.31 In reply to 7279.29
Yes, that's correct, some usage notes earlier in this thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7279.9
quote:
NOTE
The closed shapes must be drawn in the top view.
If you want to hatch several closed curves at once they must be all on the same Z plane.
7279.32
Last example combine with command Make2D4Views
http://moi3d.com/forum/messages.php?webtag=MOI&msg=8041.1
Chri
EDITED: 1 Mar 2021 by CHRI
Size: 391.8 KB, Downloaded: 133 times, Dimensions: 1671x941px
Very convincing!
7279.34 In reply to 7279.27
Where can I find this feature?
If the filling surface is a surface, what can we do?
thanks!
7279.35 In reply to 7279.34
Just load these files unzipped in the moi commands folder
and make a shortcut on it
write HatchItWithRotation or hatchItwithRotation or HAtchItwithRotation etc...but without space
or Press Tab and write HatchItWithRotation but without space
https://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=49a2a6271e520996f071e7324a59a40e&filename=HatchItWithRotation.zip
7279.36 In reply to 7279.27
Can you tell me how to operate it?
7279.37 In reply to 7279.36
Hi dangerhu, are you on Mac or Windows and what version of MoI are you using? That will help me to give you more precise instructions for how to install and run this plug-in script.
Show messages:  1-18  19-37
