MoI GUI Builder released for Mac and PC!
 1-16  …  37-56  57-76  77-96  97-104
7245.77 In reply to 7245.76
Hi Marv,
> I attempted to put the scripts into the command folder and when trying to save
> got an "Access Denied" message. That stopped me.
In newer versions of Windows, Windows will by default prevent programs from modifying anything in the "Program Files" (or "Program Files (x86)") folders, unless the program is running with elevated privileges.
If you're trying to unzip directly into that commands folder, try right-clicking on your unzip program and choose "Run as Administrator", so that it will be running with elevated privileges and then be allowed to unzip into there.
Or another way you can do it is to unzip it to some other place like your desktop, and then use the Windows File Explorer to copy the files over - instead of just ending with an error message, Explorer should put up a Yes/No dialog and if you say yes there it will use the elevated privileges just for that file copy.
7245.78
There's a new update to MGB, so please click the button 'check for updates.'
Michael changed the latest Mac version app name to "MoI v3.1.app" and MGB looks for the legacy name: "MoI v3.app"
I've now fixed it. You should press the check for update button on the top right of the interface, and it will automatically update the program. No need for Windows users to update, but if you do things should work just fine.
7245.79 In reply to 7245.78
I couldn't find the answer by searching here or on Chip's site, so can anyone tell me what the "Externals" folder is for? It's empty on my install.
Also, I'm sure I asked this at some point in this thread, but is there a way for MGB to read the current CSS file for MOI so you don't have to recreate something you've already done prior to installing MGB?
Thanks!
Paul
7245.80 In reply to 7245.79
Externals -- no need to worry about it.
No way to read an existing CSS...would require me to write my own CSS renderer/parser. Sorry.
7245.81 In reply to 7245.3
WOW! That's CLASS!
7245.82 In reply to 7245.40
Created a /New Discussion/ labelled: ICONS-GUI, where I posted icons and GUI design suggestions...
7245.83 In reply to 7245.1
Hi Chipp,
I'm getting a "Stack not found" error when I try to launch the builder. What am I doing wrong? Running MacOs Sierra
7245.84 In reply to 7245.83
I'm not near a Mac right now.
Did you unZip everything before running it? There's a single file called MoiGUI.livecode which should be in the same folder as the app bundle.
7245.85 In reply to 7245.84
Unzipped everything, .livecode is in the same folder with the app bundle. When I click on the icon the GUI Builder Start screen pops up for a second then a message "A stack cannot be found" appears.
7245.86 In reply to 7245.85
Try moving everything to your desktop and run there. It may be a permissions issue.
7245.87 In reply to 7245.86
Tried that, same problem, it might be Sierra.
7245.88 In reply to 7245.87
Ok. I'll check it out
7245.89 In reply to 7245.87
Hi Neo,
Unfortunately, it must be Sierra. I still have El Capitan installed on my Mac and it works perfect there. Unfortunately, I don't have the time right now to update this Mac, but I will try a bit later on. I have a laptop I should go ahead and update and when I do I'll look into it.
I'd suggest making sure your protection allows for running non-signed apps and also that you have permissions to run it.
Please review below and make sure:
1. You have the correct file structure
2. You have correct permissions
https://altuit.cloud/web/dbpub/3D/MoiGuiConfig.png
Michael,
For some reason using syntax below no longer works. This keeps me from posting images using a URL (thus not bloating your forum).
<img src=https://altuit.cloud/web/dbpub/3D/MoiGuiConfig.png>
7245.90 In reply to 7245.89
Hi Chipp, re: <img> tag, the src= attribute needs to have double quote characters around the URL, like this:
<img src="https://altuit.cloud/web/dbpub/3D/MoiGuiConfig.png">
7245.91 In reply to 7245.90
Thanks. I thought I tried quotes as I know that's proper HTML, but before it worked w/out the quotes. Thanks!
7245.92 In reply to 7245.87
Neo,
You might want to download the free LiveCode then just open the MoIGUI.livecode file and see if it doesn't work.
Once you open it, it should just 'play'-- no need to do anything else. I'd suggest V7 or V8.
7245.93 In reply to 7245.92
Chipp,
Downloaded LiveCode v8 opens the file in edit mode does not run. How do you run the stack within LiveCode, is it by clicking on the play button? If so mine is ghosted.
7245.94
Hello. Thanks to everyone who has contributed / is contributing to this GUI project. I really appreciate the efforts -- especially for a darker interface!
EDITED: 16 Oct 2020 by JOELDBERRY
7245.95 In reply to 7245.1
Hello Chipp, I am sure you're doing awesome.
I couldn't download the zip file from the link that you posted,
it keeps giving me an error. So, I got in touch with Michael
and he sent me the App. The App, unfortunately doesn't open.
'A stash cannot be found' is the message.
Can you please help? Thank you in advance.
Sandeep.
Size: 751.7 KB, Downloaded: 156 times, Dimensions: 842x1078px
Just downloaded the guibuilder again, along with the latest livecode.org open source build.
The guibuilder exe works fine and the stack loads into livecode and runs live with no errors...
The download link in the initial post worked fine. Maybe you need to start with "why that didnt work for you"...
There was also an update to the stack downloaded to the initial download...
Show messages:  1-16  17-36  37-56  57-76  77-96  97-104
