Hi Marv,
> I attempted to put the scripts into the command folder and when trying to save
> got an "Access Denied" message. That stopped me.
In newer versions of Windows, Windows will by default prevent programs from modifying anything in the "Program Files" (or "Program Files (x86)") folders, unless the program is running with elevated privileges.
If you're trying to unzip directly into that commands folder, try right-clicking on your unzip program and choose "Run as Administrator", so that it will be running with elevated privileges and then be allowed to unzip into there.
Or another way you can do it is to unzip it to some other place like your desktop, and then use the Windows File Explorer to copy the files over - instead of just ending with an error message, Explorer should put up a Yes/No dialog and if you say yes there it will use the elevated privileges just for that file copy.
