MoI GUI Builder released for Mac and PC!
 1-16  17-36  37-56  57-76  77-96  97-104
7245.37
Sorry I haven't gotten around to making all the changes yet. I've been slammed at work and have to finish other projects on the weekend. I hope I'll get to it this coming weekend :-).
7245.38 In reply to 7245.36
Hi Jay,
> Is there a way to change this frame?
That's controlled by the class named SceneBrowserSwatchActive in moi.css, in its border property:
.SceneBrowserSwatchActive {
border:1px solid rgb(80,80,80);
border-radius:2px;
7245.39
New Update: 0.9.32
Added the following:
  1. Hover and active colors for LabelButton
  2. Active color for PushButton
  3. Hilite border color for Container and StylesContainer takes color from the buttons shown at bottom
  4. Background color for Container and StylesContainer
  5. Border color for SceneBrowserSwatchActive
  6. Background color for FilenameContainer
  7. Scrollbar background color*
  8. Scrollbar thumb button color*
  9. Check out Icon Builder
    * These effect all scrollbars other than the one used for the shortcut keys (no way to edit CSS for those). If you use these be aware you will NOT see the left and right scrollbar arrows. This shouldn't be a big miss, and may in fact create less visiable clutter.
    As usual, you only need to press the Check for update button at the top right of the interface to download this update.
7245.40 In reply to 7245.39
Icon Builder
Icon Builder allows anyone to build sets of correctly named icons, using their own icons if they wish. When it first opens, it will attempt to create a folder (make sure this app is placed somewhere with write permissions!) called moi_icons.
There is nothing to do, as there are no files yet in THAT folder. So, download the base files:
https://altuit.cloud/web/dbpub/MoIGUIdownloads/BaseIcons.zip
Unzip them and put them in the folder.
The anatomy of a base file:
  • It's a 64px x 64px transparent PNG.
  • It only has 1 color (black or whatever you like. It can be changed in Icon Builder.
  • It's name is EXACTLY the same as the icon it will be replacing.
The interface:
  1. Button to launch the Icon Builder window
  2. The Backdrop button sets the background of the Icon Builder window
  3. The icons in the folder will be shown one at a time. You can press PREV and NEXT to step through them. If you add new icons to the folder, just close and open the Icon Builder window to refresh the list of icons.
  4. You can set the color of the icon AND the hilite glow color around the icon. You only need to set this once. Not necessary for each icon as when you SAVE it will apply the current color and hilite settings to all icons.
  5. When you are satisfied with the color scheme, you can press the Save Icons button and choose a folder to save the icons in.
You will need to know the correct location for where to put the newly rendered icons. For the icon in BaseIcons.zip, you should put the newly created icons in the moi/ui/icons folder.
If you create new base icons, please share links to them in this thread!
7245.41
Example uses the darkinterface preset.
Notice scrollbar at bottom is much less prominent. Also, the icons are customized to match the color of the interface.
7245.42
Here's the existing ICONS which will work for both LIGHT and DARK interfaces. You can colorize them however you like in Icon Builder. See below for exceptions*
*Not sure how to replace the Copy, Paste and History Icons...Michael?
*The Dark icons at the bottom are base64 encoded directly in the htm file. Perhaps the htm file can be modified to look first for an icon name and if it doesn't find it use the base 64 encoded version? Max?
Icons for Light Backgrounds:
https://altuit.cloud/web/dbpub/MoIGUIdownloads/IconsForLightBgs.zip
Icons for Dark Backgrounds: (Like above)
https://altuit.cloud/web/dbpub/MoIGUIdownloads/IconsForDarkBgs.zip
Remember, put these in your moi_icons folder in MGB. It will use these to build out the full set (minus what you see above). Then save to your icons folder in moi/ui/icons
(please back up!)
7245.43 In reply to 7245.42
*Not sure how to replace the Copy, Paste and History Icons..?
Those are being drawn as a resource from the application.
What you can do is edit the sidepane.htm file to change them from a resource to an icon asset. The 2 lines are listed below.
<table><tr><td>&lt;moi:CommandButton icon="res://copyclipboardicon" command="copyclipboard" rcommand="copyclipboardwithorigin"&gt;&lt;moi:Text textid="Copy clipboard"&gt;&lt;/moi:CommandButton&gt;</td>
<td>&lt;moi:CommandButton icon="res://pasteicon" command="paste" </td></tr></table>
Just change the Res : / /xxxxxx lines to regular "icon="icons/xxxxx.png" lines..........
EDITED: 17 Mar 2015 by BURRMAN
7245.44 In reply to 7245.43
Thanks. For other Resources, Michael has provided a mechanism to replace them by just putting a correctly named file in the icons folder-- without having to edit the htm of a specific file. I'm trying NOT to touch anything but the moi.css file (so far that's all I change in MGB). Of course Icon Builder creates new icons which must be manually moved to the icons folder.
I'm hoping there is something similar for these icons as well.
7245.45 In reply to 7245.44
Hi Chipp, yes the same thing should apply to the Copy, Paste, and History icons (info on this here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6325.5).
If you place files named CopyClipboardIcon.png, PasteIcon.png, and HistoryIcon.png in the /icons sub-folder they should get picked up and used without needing to change the side pane code itself.
To see which specific name to use (like you probably got tripped up because Copy needs to be "CopyClipboard", the other kind of copy is the Transform > Copy command), look at the button code to see what is used there for the res:// protocol, like for example for Edit > Copy it says: icon="res://copyclipboardicon"
EDITED: 18 Mar 2015 by MICHAEL GIBSON
7245.46 In reply to 7245.45
Thanks Michael,
Yes, you are correct. I did try using the obvious names to no avail. Good tip by you and Burrman on where to find the names! Much appreciated. I'll soon update the icon files links with the new icons.
7245.47
Added the icons to the ZIP collections referenced above:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7245.42
Also added a feature which effectively DOUBLES the intensity of the colorization (see checkbox below).
Created this new set in about 10 seconds.
7245.48
A couple more interfaces to show how you use the IconsForDark vs IconsForLight version.
This one is fairly generic and uses the IconsForDarkBgs.zip and the darkInterface theme template with light gray icon color and black hilite color:
And his one is fairly generic and uses the IconsForLightBgs.zip and the MediumInterface theme template with black icon color and white hilite color:
If you colorized the top interface with the IconsForLight, all the icons would look like a NEGATIVE (inverted) version, and of course the same is true if you colorized the bottom set of icons using IconsForDark.
It's best to think of it this way:
If the global text is overall darker than the background, then you should use IconsForLight. If the global text is overall lighter, then use the IconsForDark. Hope that clears things up :)
EDITED: 18 Mar 2015 by CHIPPWALTERS
7245.49
Hi Chipp, thank you!
7245.50
Just a workflow update. I think setting icon colors may be bit of a struggle for some. So I created this video showing how to use MGB and in particular the Icon Builder part.
Also, here's a view of the latest interface I'm currently using. Here's a link to the MGB Template file:
https://altuit.cloud/web/dbpub/MoIGUIdownloads/modo01.txt
Have you seen MoI Interface Builder?
Smart result and cool video tutorial! :)
French site updated! :) http://moiscript.weebly.com/mgb-interface.html
PS Seems all your pieces of the moto car are individually named ?
EDITED: 3 Apr 2015 by PILOU
7245.52 In reply to 7245.1
Thank you Chipp, I did not look at the forum for a while now but I am amazed what for cool stuff is contributed by you and many others for this great App.
7245.53 In reply to 7245.50
Awesome stuff......do you mind posting a link with a zip for all the icons for this modo theme?
I am really digging this look.
how you got this xyz gizmo on the lower left of the viewport?
Thanks for all you hardwork chipp!
A.
7245.54 In reply to 7245.53
I believe the setting for the gizmo visibility is in the options panel.
I'm not currently at my computer but I will zip the icons and for them when I get there. Please re-read the previous posts as some of the icons go in different places.
7245.55 In reply to 7245.54
Thanks for the quick response....sorry but i am new to Moi.....I have Alot of catching up to do regarding the customozation of this awesome software.
My apologies.
A.
7245.56
New Updates
First off, I've got a whole package for those of you who don't want to mess with MGB but would like to use the MODO-like interface. Here's the interface (right-click to view full scale):
A few things to note about this interface. Most of you know, earlier on I created icons for the document management part on the lower left. Now, I've recreated Max's icons so they will work with the Icon Builder component of MGB. So, now it's easy to colorize them as well as all the rest of the icons.
Also, I've added new icons for Max's new SDS scripts, including SDS, Split, Bridge and Scale. Plus, there are an associated group of script commands (and edits) which are used to place them at the bottom next to Max's other scripts. More on that later.
So, in order to use this exact same interface, here's what you'll need to do:
1. Download these files
MODO moi.css:
https://altuit.cloud/web/dbpub/MoIGUIdownloads/MODOmoi-css.zip
MODO icons
https://altuit.cloud/web/dbpub/MoIGUIdownloads/MODOicons.zip
MODO interface images:
https://altuit.cloud/web/dbpub/MoIGUIdownloads/MODOinterfaceImgs.zip
Max Scripts (Only if you have his toolbar and subD scripts installed)
https://altuit.cloud/web/dbpub/MoIGUIdownloads/maxButtons.zip
2. BACKUP all of MoI and it's config files!
Don't make me say 'I told you so!' ;-)
3. Put them in their CORRECT Locations
Here are the files..
moi.css
It goes in the
moi/ui
folder and replaces the existing one there.
icons
There are MORE icons in this new MODO icons folder (built by MGB icon builder) than currently in your
moi/ui/icons
folder. Be sure to copy and the files in the download icons folder and replace them in the existing
moi/ui/icons
folder.
interface images
These will replace the existing images with the same name in the moi/ui folder.
Max scripts
These all go in the
moi/ui/customui
folder. If you don't have this folder then you don't have Max's tools installed. You'll need to go to his thread and install from there first.
NOTE: I edited some Max scripts to remove the embedded icons and add the newly built generated icons. No other functional changes were made.
  • 70 ObjLibrary.htm
  • 80 ExtScripts.htm
  • 84 Snapshot.htm
  • 88 LightingPresets.htm
Also, I've ADDED the following html script files, which also go in the
moi/ui/customui
folder. They of course have matching icons which you've already installed.
  • 94 Scale.htm
  • 91 SDS.htm
  • 92 Split.htm
  • 93 Bridge.htm
A couple other things to remember:
  1. Max's scripts go along the bottom, from left to right based on the NUMBER before the file name. So,
    94 Scale.htm
    will show up to the right of
    93 Bridge.htm
  2. Placing a
    in front of a htm file will disable it from being shown in the interface. So, to hide the Snapshot button, just change it’s name to
    -84 Snapshot.htm
Other stuff
If you want to recreate your own icon color schemes, I've updated the icons for both Dark and Light backgrounds. So, please download the new versions:
Show messages:  1-16  17-36  37-56  57-76  77-96  97-104
