AMONIT modelling
 1-20  21-36
7172.1
normally I use MOI for simple objects. I´m not so good/experienced in MOI.
That´s the reason why I can´t evaluate if it is possible to model an amonite with MOI.
Would be nice getting a feed back.
EDITED: 11 Jan 2015 by MALA
7172.2 In reply to 7172.1
This Ammonite?
https://www.google.md/search?q=ammonite&es_sm=93&biw=1097&bih=565&source=lnms&tbm=isch&sa=X&ei=zCqyVJyuJ-K_ygP2wYKgCg&ved=0CAYQ_AUoAQ
If yes MoI is not good for this work. It will be better to use sculpting software. Or make base in MoI and then made all organic details in Sculpting software.
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
7172.3 In reply to 7172.1
Hi Lara, yes things that are more organic shapes with a kind of melty lumpy type form are not really very suitable for modeling in MoI. MoI is primarily focused on creating models by construction from 2D profile curves and it's difficult to create such forms from profile curves alone. Sculpting software such as 3D-Coat, ZBrush or Sculptris may be some good ones to try for organic shapes with bumps and ridges in them.
7172.4 In reply to 7172.2
The logarithmic spiral script might help.
Maybe a script could be written, as per the paper referenced at the end of this article:
http://www.sott.net/article/287395-Physicists-develop-model-of-ammonite-coiled-spiral-shell
The math would take a lot of study :-)
-Brian
7172.5
thanks for your tips and experiences.
After all I do need a model which is more an abstract ammonit object than a high detailed one.
Similar like attachement...
EDITED: 10 Feb 2021 by MALA
7172.6
This are 2 of my attempts in moi.
If abstract is what you are looking for you might find a way.
But still it's a little tricky.
I'm not a very experienced MOI user.
I gave it a try to see what i could come up with.
I drew a flat spiral and drew a base shape for one high and low rickle( or how you like to call it :) )
I unwrapped the spiral, wich gives you a flat line
I copied the base shape 70times on this line and then used flow to flow it on the spiral.
Before i copied the base shape i added a point at its center.
So after i flowed it i could still run the scale array command to scale everything down a bit, big to small from the outside to the center.
It didn't exactly give me the result that i wanted.
In the center it got a little bit mixed up and had to fix it a bit.
Maybe it would be better to run scale array before flow.
But hey, maybe this will get you started. :)
Glenn
7172.7 In reply to 7172.6
The logarithmic spiral script is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6951.1
7172.8
Hello guys,
thank you very much for your help.
At the moment I can´t try your suggestions out - I´m a little bit job stressed.
I will give you feed back asap.
Best regards
P.S.: How do you run such a script in MOI?
7172.9 In reply to 7172.8
Unzip an Put the files in the commands' Moi folder
Press Tab then write _LogSpiral on the bottom numeric box then Press Enter
(better if you have a file text with all the name's scripts so just make a copy past! ;)
(you can also make a ShortCut with _LogSpiral in the second column )
That's all :)
EDITED: 12 Jan 2015 by PILOU
7172.10 In reply to 7172.9
I do not know and I didn´t find the commands folder?!
P.S.: Sorry. I searched the folder in the GUI. I got it now in the program structure and put the files into it.
But I got a script message. Is this script working with MOI 2?
EDITED: 12 Jan 2015 by MALA
7172.11 In reply to 7172.10
Sorry I don't know, I don't have more the Moi V2!
What is the error message ?
7172.12 In reply to 7172.11
Attachment!
7172.13 In reply to 7172.12
Options / General / Language/ English for have an answer by Michael! ;)
7172.14 In reply to 7172.13
Could you make a simple example object and a screenshot of it. In order to see weather it is a script that goes the amonit way at all...
7172.15 In reply to 7172.10
Hi Lara, I think the script is only working with MoI v3.
The script itself is not going to draw a finished solid for you, it will just give you a precise curve. If you don't need an extremely precise curve you can just draw a curve of similar shape using Draw curve > Freeform > Control points.
7172.16 In reply to 7172.6
Hi Glenn,
I tried to start your concept. But I need some help because some points I did not follow. (Because of my poor english and my poor MOI skills)
Here is what i do not understand of your concept:
1:
"I unwrapped the spiral, wich gives you a flat line"
Means unwrapped the sweep function? How to unwrap? Where comes then the flat line from?
2:
Which function brings it onto the helix?
Would be nice to here from you!
7172.17 In reply to 7172.16
1 . Unwrap : It's a command who unfold your curve (here an helix) on an straight line (you must load the 2 files! )
This line will have the lenght of the curve of course!
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5136.1
Select the any curve
Press Tab then Write unwrapcurve (or copy past this word from a list text file - you can also make a shortkey)
2. Flow Command. It's an internal Command of MOI: Menu Transform / Deform / Flow
http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
EDITED: 13 Jan 2015 by PILOU
7172.18 In reply to 7172.17
Hello Pilou,
thanks for your MOI training.
Becauce I have MOI 2 the FlowCommand is not available for me. Should be in MOI3?!
Perhaps I can progress my Amonit with these new skills.
Thanks.
7172.19 In reply to 7172.18
<< Should be in MOI3?! Yes Flow is only the V3!
But you can modelise your object without this function ;)
Maybe Scale Array can help you! ;)
http://piloumaison.weebly.com/le-scale-array.html video in French but very visual :)
http://moi3d.com/forum/messages.php?webtag=MOI&msg=275.107 use of the plugin
EDITED: 14 Jan 2015 by PILOU
7172.20
Hi Lara,
I'm not that skilled either.
We learn step by step.
Trying to help you out learned some new things too.
I see that Pilou basicly told you what you didn't understand.
So far I learned that there is always more than one way to get a certain result.
Flow isn't realy necessary as I also used scale aray , as Pilou suggested.
As for a base shape, look at the last example that Pilou posted.
It's one "base" or "Basic" shape that has been copied several times.
So you don't have to model all of them sepperatly.
When you go to the copy tool you have several choices.
One is to copy on a line.
So what you should do is model just one of those sections until you have a shape that you like.
Then copy it and use scale aray.
(Note that you have to put a single point at the center of the base shape you make.
You need this for the scale aray function.
You can use the command " bounding box center " to do this
If you want a nice smooth curvy surface as a end result.
You could select all the edges that you copied on the spiral and do a loft.
But it will be important to select the edges in the correct order to give you a nice result.
Hope it helps.
Otherwise, the experts such as Pilou can probably help you better than me!
Show messages:  1-20  21-36
