MoI Fingerprint Ring
All  1-9  10-16
7137.10 In reply to 7137.9
Mikey -
I make sure the ring is a solid before proceeding.
I made a rectangle surface with an area equal to the width of the ring, times the circumference of the ring.
I positioned my extruded fingerprint so the desired depth extends below the rectangle.
Transform > Deform
Select Object to Flow: I select just the entire fingerprint.
Select Base Curve or Surface: I click on the rectangle on the right-hand side near the closest edge (shown by my red dot).
Select Target Surface Near Matching Side: Imagine the rectangle is wrapped around the ring. I click on the ring close to the corresponding place where I clicked on the rectangle (shown by my red dot).
After the fingerprint is flowed, I boolean diff the fingerprint which leaves the recessed areas.
Size: 22.8 KB, Downloaded: 81 times, Dimensions: 500x229px
7137.11 In reply to 7137.9
Hi Mikey, also see here for the help page on the Flow tool:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#flow
And also see here for some links to previous discussions in the forum:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6746.5
7137.12 In reply to 7137.10
Ed-
Thanks so much for the explanation will give a try and post!!!!!!
7137.13 In reply to 7137.11
Thanks Michael!!! Excited to give this a shot!!!!
7137.14 In reply to 7137.10
Hi Ed!
Thanks for the Flow Tut! Ive attached a pic! Totally understand it now. Here's an issue that I'm running into and Im sure I'm doing something wrong. When i attempt to do a boolean difference on the ring nothing happens. I select the ring as the base and the pattern as the subtract. It then proceeds to calculate but nothing happens. any ideas?
Size: 115 KB, Downloaded: 41 times, Dimensions: 811x713px
7137.15 In reply to 7137.14
Hi Mikey, re: booleans - it can be difficult for booleans to handle cases where objects have overlapping surface areas where they are just barely skimming through each other.
So because of that when you do a flow it can be a good idea to make the objects stick some distance pushing through the object rather than trying to place them with their bottoms or tops just skimming right along the same surface area.
7137.16 In reply to 7137.15
Got it! Thanks again Michael!
Show messages: All  1-9  10-16
