Polygonal Converter.
 1-6  …  367-386  387-406  407-426  427-446  447-466  467-483
Message 6674.407 deleted 30 Oct 2016 by STEFAN
Message 6674.408 deleted 7 Oct 2015 by STEFAN
6674.409 In reply to 6674.403
Hi Vojtěch,
>>I know this is lot of work in your free time, but do you plan something like Creasing edges?
Here is my subdiv script development plan:
- rewrite importMesh function (again)
- increase surface quality when smoothness setting <40
- improvements of open surfaces processing
v1.0 release (11.2015)
- increase overall performance of the script, rewrite couple of functions
v1.1 release (01.2016)
- per-edge crease settings
- surfaces stitching
v2.0 release (1h 2016)
- full support of triangle surfaces
- on-the-fly shape manipulation
v3.0 release (???)
6674.410 In reply to 6674.409
Max,
FWIW, I think you should charge $ for this. It's very worthwhile. A similar type plugin, Artisan, for SketchUp is commercial. I know the guy who wrote it. Like you he had given lots to the community. By charging for one plugin, it was a way for those in the community to help support his continued efforts. And, as we all know, a 'contribute PayPal' button doesn't do very much these days.
Thanks for your tireless contributions! Really good stuff. :-)
6674.411
Yes, an I could charge for tutorials! ;-)
But yes Max, very good job on such a valuable script, and thanks for the hours of effort - I for one will put it to use.
6674.412 In reply to 6674.409
Will looking forward :).
And as wrote Chipp, contribution from users is something you should consider to help you with development.
Thanks for your work
Vojtěch
https://vojtisek.artstation.com
6674.413
I agree, this is definitely a development path worth investing in. Actually, I would prefer it if Max and Michael would get together and develop this into a fully integrated tool inside MoI. Especially in order to make the final 'on-the-fly shape manipulation' really come together.
I'm not sure such a brilliant synergy would ever happen though. MoI currently has a different toolset and philosophy, and I'm afraid it's outside of Michael's scope. At least for now.
Keep up the good work, Max!
6674.414
Thank you, guys!
I found program block which allows to load selected objects separately. I used it in beta3, but I turned it off in beta4. Don't ask me why :) I just forgot about it.
Today I turned it on and I was shocked. Look how it works with open surfaces :)
Also I improved open surface engine. Now it processes vertices with more than two naked edges correctly (right one).
EDITED: 7 Mar 2022 by SMIRNOV
6674.415
Wow! It looks really good!
P.S. Need to sleep. I'll post the new version tomorrow.
6674.416 In reply to 6674.415
My self-portrait after seeing the above two postings:
=:0
Pretty nail! :)
6674.418 In reply to 6674.415
Hi Max,
Hope you get a good night :)
I was looking at your road map, and I'm wondering if anything is planned about a possible surface simplification in the future ? By simplification I mean less edges on the sub-d converted model.
If I remember right t-spline for example only build patches between extraordinary vertex (or something close)
In other words a quad ball with 1 level of subdivision or 5 level of subdivision give the same edge structure once converted. Of course the patches get much more control points.
I'm asking that because it will allow us to use tools like partial edges tension in software like modo.
Here for example a partial edge crease (weight) on a low res model (A). This function is very handy.
(B) on the other hand it the freezed version (so the subdivsion is collapsed).
While the polycount on (B) looks insane, the number of extraordinary is the same than (A).
If I convert model (B) in T-spline, I would get the same numbers of patches than Model (A) ... only more complex patches.
EDITED: 3 Dec 2015 by PAQ
6674.419
Hi Max,
The latest SubD incarnation is fantastic - something that perhaps you could add in the future to the SubD toolkit is a Pipe Command similar to the TSplines Pipe SubD Modelling from 3d wireframes.
https://www.youtube.com/watch?v=VWRvmmhJBRg
More food for thought.
I also agree that this toolset is becoming so advanced that a pay for model to support your efforts are worthy.
Thanks for time input.
6674.420
PaQ
I called it surfaces stitching. ( I don't know is that correct name? )
It has been scheduled for version 2.0
AlexPolo
>>I thought about such a script. Maybe someday I'll write it. :)
6674.421 In reply to 6674.420
Hi Max,
Yes sorry, I didn't understand the 'stitching' term (my bad).
And I'm pretty sure you all ready talk about it previously, but boy, ... this is the longest MoI thread ever created I guess :)
Thanks for you dedicated work !
6674.422
Beta9
- loadMesh function has been improved
- increased overall stability
To get hard edges just split object to several surfaces and then run script.
6674.423
Max, this is absolutely amazing! Can't wait to play with it. :-)
6674.424 In reply to 6674.422
That's awesome, thanks!
Vojtěch
Cool trick for the "crease borders" ! :)
Here the French Version (even with the Alert Messages that i have never think to translate! :)
http://moiscript.weebly.com/subdivision.html
@Max
Can you put something on each start lines code (or before each line) where there is something to translate ?
Because it's an hard work to refind all lines that must be translated in your tremondous codes when there is no ressource file!
Thx by advance for that! :)
/* Careful Pilou next line something to translate! */ or something more smaller like /* */ if you want or more smaller if exist or color words or... :)
<moi:CheckButton id="preserveCorners" default="true">Preserve corners</moi:CheckButton>
EDITED: 9 Oct 2015 by PILOU
6674.426
Beta9 update. Fixed bug with polar triangles with open edges.
Frenchy Pilou
When I write a complex script I always use a lot of comments. And I delete them automatically before publishing.
So it's not a good idea for me to mark text lines with comments. I'll think what I can do.
Show messages:  1-6  …  347-366  367-386  387-406  407-426  427-446  447-466  467-483
