Polygonal Converter.
 1-18  …  339-358  359-378  379-398  399-418  419-438  …  479-483
6674.379
Frenchy Pilou
>> My volume above has not extraordinary faces ?
Yes, there are extraordinary faces in your model.
At this moment the script supports extraordinary quads only, not triangles.
bemfarmer
>> Is there a purpose of the comma after the curly braces: },
The purpose of a comma separator is to delimit members in a list.
For example:
var obj = {
  a: 22,
  b: 33,
  c: function() {return this.a+this.b},
  d: function() {return this.a*this.b},
  e: function() {return this.a/this.b}
Mike K4ICY
>> I hope that open surfaces and extraordinary polys are a possibility someday...
I'll try to make it in the nearest future. 1-2 months.
BurrMan
>> you can preview a kindof "harder edge" output
I remember about this. It's old bug of hq mode. I just had no time to fix it, but I hope I'll do it soon.
So, don't use it that way :) At least now. ;)
Michael Gibson
>> control points, weights, knot vector, degree, etc...
It will be great! Thank you.
EDITED: 7 Mar 2022 by SMIRNOV
6674.380 In reply to 6674.379
Excellent job Max! Thank you.
... only SubD exercise + blend... extravagant "Caraffa Cuore" :-)
render in Octan has to be improved... some triangle artefacts appeared.
Mik
Size: 605.8 KB, Downloaded: 137 times, Dimensions: 1600x1200px
6674.381
I've made two illustrations which might help you to understand what extraodinary faces is.
A vertex surrounded by three (1) or more than four (3) faces is called extraordinary vertex. And a vertex surrounded by four faces (2) is called ordinary.
If one or more vertex of a face is extraordinary, this face is called extraordinary too.
My script can load meshes with following types of polygons:
A - Ordinary quads ( 4 ordinary vertices ) - full support, best quality
B - Extraordinary quads ( 1 or more extraordinary vertex ) full support, best quality
C - Ordinary triangles ( 3 ordinary vertices ) looks good, but sometimes an artifacts can be noticable,
D - Extraordinary triangles ( 1 or more extraordinary vertex ) doesn't support at all. produces noticable artifacts on all neighbour faces.
E - Polar triangles ( group of triangles with a common vertex, two other vertices of each triangle must be ordinary ) full support, best quality.
So, you should not use type C and type D polygons.
6674.382 In reply to 6674.381
THX for the detailed infos!
6674.383
Beta8 will be soon ;)
6674.384 In reply to 6674.383
Seems there are some new concepts realized!
6674.385 In reply to 6674.383
Trying to imagine if you get this down to the vertex level..
6674.386
Looks like you're making great progress, Max! Can't wait to try those open surfaces!
Really amazing to see this in MOI - thanks again for all your efforts!
6674.387 In reply to 6674.383
Hey Max,
Do you think it might be possible to have an option to crease open edges ?
In practice it should even be the 'default' behavior, but I'm probably biased by Modo default settings.
EDITED: 3 Dec 2015 by PAQ
6674.388
BWAAA!!! SOOOO AWESOME Max! :-) ..oh, the evil plans are a conjurin'
6674.389
I think PaQ's suggestion would make a lot of sense as a 'default'. Having an option to crease other (non-outer) edges would be the icing on the cake, if possible ;-)
6674.390
Hi guys!
archetype
Next weekend, I hope. Maybe earlier, maybe later :)
It's possible, I have it in the plans.
PaQ
Yes. I've wrote this script block yesterday.
6674.391 In reply to 6674.390
It's looking great Max!
6674.392
Wonderful, thanks Max !
6674.393
That amazing Max!
6674.394
Woah! Sweet!! Need to create a tutorial on *that* version!
6674.395
Thank you :)
The work is going on successfully.
I need from two to five days to finish it. In fact I can do it during one evening, but I'm busy at work (as always) :)
Somptuous!
6674.397
Can't wait! :-)
Thickness possible or problematic for the last example?
Show messages:  1-18  …  319-338  339-358  359-378  379-398  399-418  419-438  439-458  …  479-483
