Loft Andrei Samardac
All  1  2-5
6263.2 In reply to 6263.1
Before a script you can select all curves in one click by the help of the Browser!
Objects / names, Types/curves or Styles/ colors for example!
Else here the shortcuts of Andrei ;) file ini is linked but not each scripts considered
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5948.1
EDITED: 9 Nov 2013 by PILOU
Some Andrei scripts are here! bottom message 10
http://moi3d.com/forum/messages.php?webtag=MOI&msg=6058.6
6263.4
6263.5
I use this script in my tutorials:
script: /* Expand selection over same styles and loft */ var objects = moi.geometryDatabase.getObjects();var styles = new Array();for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.selected ) styles[obj.styleIndex] = true; } for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( styles[obj.styleIndex] ) obj.selected = true; }; moi.command.execCommand( 'loft' );
This script works this way:
- It selects all with the same style
- Make loft.
Just make all curves you want the same style with this script:
script: /* Asign style*/ moi.ui.propertiesPanel.editStyleIndex( moi.geometryDatabase.addStyle().index );
EDITED: 10 Nov 2013 by ANDREI SAMARDAC
Show messages: All  1  2-5
