Just want to share my .ini file with shortcuts. May be it will useful for somebody.
Have no idea how I remember all this shortcuts but I practical dont use user interface only shortcuts.
I achieve big speed working in moi, but can not say the same about Rhino workflow in it is too slow too many commands... Moi best part is that Michael grouped many commands in one.
For example in Rhino - fillet curves, fillet surfaces, fillet solids. Moi have one - Fillet that work in all cases. If I made this shortcuts for rhino it would be 3 times larger I think.
It consist some special scripts.
'=AddPoint
,=Offset
-=box
.=shell
/=inset
0=circle
1= 'top'
2= '3d'
3= 'front'
4='right'
5=Line
6=Polyline
7=Curve
8=rectangle
9=RectCenter
;=ShowPoints
=boxcenter
\=spherer4
`=Show edges on selected objects, hide edges on all others
A=mirror
Alt+B= Extend selection to same names objects
Alt+C=intersect
Alt+F=chamfer
Alt+G=Scale2D
Alt+M=merge
Alt+O=Inset
Alt+R=Rebuild
Alt+S=save screenshot
Alt+V=change light source
Alt+Z=zoom selected
B= Assign unique object name to selection and hide
Backspace=cylinder
C=chamfer
Ctrl+1=ArrayCircular
Ctrl+2=ArrayDir
Ctrl+3=ArrayCurve
Ctrl+`= show hide edges
Ctrl+A=select all
Ctrl+B= Assign unique object name to selection
Ctrl+C=CopyClipboard
Ctrl+D=ShrinkTrimmedSrf
Ctrl+E=select last created object
Ctrl+L=CenterAtOrigin (set object at 0.0.0)
Ctrl+M=nacke deges
Ctrl+N=New
Ctrl+O=Open
Ctrl+Q= SeparateSelectOuterLoopsDeleteTrim
Ctrl+R=Rebuild
Ctrl+S=Save
Ctrl+Shift+C=CopyClipboardWithOrigin
Ctrl+Shift+V=PastePart
Ctrl+Shift+Z=script:moi.command.redo();
Ctrl+V=Paste
Ctrl+W=SelectOuterLoopsAndDelete
Ctrl+X=Cut
Ctrl+Y=script:moi.command.redo();
Ctrl+Z=script:moi.command.undo();
D=BooleanDifference
Delete=Delete
E=extrude
F=fillet
F1= grid snap
F11= paralel view
F12= perspective view
F2= stright snap
F3=object snap
F5=network
F6=blend
F7 - Revolve
F8 - Rail Revolve
F9 - Isect
G=Scale1D
H= Hide object but keep eges visibility , if edges was hiden they stay hiden when unhide .
I= Expand selection over same styles
J=join
K=separate
L=Loop selection
M=BooleanMerge
N=Copy
O=loft
P=project
Q= set Cplain
R=Rotate
S=sweep
Shift+C=Silhouette
Shift+Space= change view from left to riht or front to back
Space= isolate
T= Open Add new style dialog
U=BooleanUnion
V=Move
W= reset CPlane
X=script:moi.view.showHiddenLines =! moi.view.showHiddenLines;
Y=trim
Z= reset All views
