Wing fuselage blend yields pinch
All  1-7  8-15
6262.8 In reply to 6262.7
Hi Pilou, which particular side happens to get picked as the seam location might be different depending on the pick order. I had previously wrote on another thread that there wasn't any difference depending on pick order, but I guess this can be an exception to that for some cases at least (probably for when the first curve's natural seam also coincides with the "twist minimized" seam location as well).
But why are you concerned about it? It doesn't really make any difference where the surface closure seam is at.
If you like you can move it by dragging the points that you see inside the viewport, but there isn't really any reason to do that.
If it helps to clarify what you are seeing, you can use the "MarkCurveStart" plugin (http://moi3d.com/forum/index.php?webtag=MOI&msg=5288.21) to place a point at the closure point for the edges you are blending between. You will likely see that one of them has its natural start position at that location where you get the blend surface closing seam.
6262.9 In reply to 6262.8
Sure no difference just surprising! :)
(and the funny i believe that i have tryed all orders and positions of clicks and never with the multiple blend i obtain the same than Burr! )
I remember at the beginning of Moi! You will have made this tricky thing! ;)
Position of the click makes different results!
"Oops, your graphic there is not quite right - you don't want to click near the middles, you want to click closer to one end than in the middle, but it needs to be on the same ends that you want to have matching.
EDITED: 8 Nov 2013 by PILOU
6262.10 In reply to 6262.9
Yup, but that was only for much earlier versions of MoI, I think before v1 was even released...
Since the problem of misaligned things like you show there was happening pretty frequently I switched the behavior later on so that the location of your pick spot did not make any difference for determining the matching direction.
Only in that old version though, not anymore! If you repeat the same thing you show there in the current version you'll see it does not make any difference where you pick anymore.
If the automatic direction finder gets things wrong, you can still flip the direction of the blend edges by clicking on one of the blend edges while you are in the final "Adjusting parameters" stage of the command.
6262.11 In reply to 6262.10
This is a great thread. I have gotten a lot of good information from everyone, thanks for posting it Brandroid. I'm also having difficulties in this area. I was trying to blend a fuselage and it won't connect right to the wing using a G2 blend @ 1.0. I have the same amount of trim points on the edges for both body and wing, however, when I use the blend it wants to place the created edges off the points of the original edge. The original points lined up on the horizontal plane. I can move the start point of the curve to link up, but only for the back side of the wing., so front side is still twisted up. Is there any way to remedy this?
6262.12 In reply to 6262.11
Hi samuraijkm, can you please post the 3DM model file with the surfaces in it that you're trying to blend? Preferably with just those surfaces pertinent to your particular problem with other stuff removed.
That would make it a lot easier to examine your particular geometry and try to give some tips. It's difficult in general to give good information just looking at a screenshot alone.
The specific number of control points in the curves used to trim things doesn't really have any specific effect on Blend - Blend is based on following the geometric shape of the edges, it adds in more sections to make the blend follow that geometric shape, it doesn't really follow anything about control point counts directly...
6262.13 In reply to 6262.12
Thanks for taking a look Michael... I uploaded a cropped version of the fuselage and the wing. I projected the curve that I was using to trim the shape onto the fuselage and marked it in Red. I left it untrimmed in case the curve needs modification before trimming. Let me know your thoughts...
6262.14 In reply to 6262.13
Hi samuraijkm, the sharp crease in your fuselage body will prevent things from getting a good blend in there - usually to get a nice blend surface the things you're blending between should be smooth. In your case there is a sharp corner in part of the blend area here:
I'd recommend getting that fuselage smooth first - with it sharply creased like that basically the blend will be trying to adapt to 2 totally different surface normals at the crease spot, that means that the blend will be separated into 2 different blends that have different shapes in that spot rather than being able to be just one single smooth blend surface.
One quick way you can try to smooth out your fuselage is to select the crease edge and put a Fillet on it.
If you want to keep the fuselage with a sharp crease on it, then instead of using Blend you'd probably want to run the wing directly through the fuselage and then boolean them together and try to use a Fillet to round out the juncture rather than doing Blend. Blend only tries to build one single big smooth juncture piece, while edge filleting can do things with sharp juncture areas by putting in smaller corner patches in between different fillet segments. So usually for things with sharpness to them it would be filleting that you'd use and not Blend.
6262.15
Trim this way and you will solve all your problems..
Image Hosted by ImageShack.us
result:
Portfolio: www.samardac.tumblr.com
Show messages: All  1-7  8-15
