Recommendation for organic modelling of a glider fuselage.
 1-14  15-34  35-40
6074.15 In reply to 6074.14
Or you could just grab the edit frame and drag everything to "flat"...
6074.16 In reply to 6074.12
Hi Brendan, yes like Brian mentions above the v3 beta has DXF import, you can get the v3 beta here: http://moi3d.com/beta.htm
But often times DXF plans may be made up of all line segments and not actual smooth curves, so if that's the case you will want to maybe use the import as a tracing guide or rebuild it or something like that instead of using it directly because you don't really want to have something that's a curved form to be made out of a whole lot of little plane fragments.
Attached is a PW51 text file, from the download link, which may or may not be different from your file.
It is space delimited, modified with decimal points instead of commas, and with "space 0" added manually to each of
the 232 points. The MoI script ImportPointFile (existing revised version), was used to import the points into MoI2, as Control Points, and also as
Points. The Control Points curve looks fairly good. The trailing edge shows one point which is irregularly placed, which may be deliberate?
(The trailing edge comes out badly with through points.) There are fewer points on the top of the cross section, versus the bottom.
EDITED: 10 Aug 2013 by BEMFARMER
6074.18 In reply to 6074.17
Made some good progress thanks to all the suggestions. Got the wing section sorted out by using the foil coordinates to create an image and then building a MoI section over the image using Freeform>Control Points.
Sorry, have more questions though!
I can't seem to shell out the attached solid? I've used Offset>Shell and also Offset>Inset and the function fails to make any changes. Any ideas?
I can carve out a piece using Boolean>Merge with a down-scaled copy of the model-solid, but would like to find out what I'm doing wrong with 'Shell'.
Also the Fillet>Fillet function does not seem to work for the junction of the fin and fuselage base (not that I'm too worried). I selected the seam and and started with a fillet of 0.1mm but no go, also any ideas on this?
Cheers.
6074.19 In reply to 6074.18
Hi Brendan,
Shell is easily confused by little perturbations in surfaces, part of how it works is by generating offset surfaces and an offset surface tracks along the surface normal of the original surface. If the surface has wrinkles in it or worse yet folds back over on top of itself those get magnified on the offset (think of the offset being like a stick on the surface, any little wiggle at the base of the stick is magnified at the tip of it).
In the back part of your model it looks like there is a self-intersecting or "folding over itself" part in these areas here:
> any ideas on this?
Fillet also involves generating offset surfaces and then intersecting them with one another, that's part of how it forms the path for the fillets to follow. So anything that hoses out offsets will usually also break filleting in those same areas as well.
6074.20 In reply to 6074.18
Here's another zoom in to just the one surface:
That looks like the kind of fold over / self-intersection as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1127.4
6074.21 In reply to 6074.19
To get a better end shape there, you probably want to either have the end come to a single point like the front part, or maybe if you didn't want to do that because it's kind of flat you might want to make it come to a flat end shape initially and then put a planar cap on the end and then fillet where they connect.
For the latter one you'd want to have the long rails end without swooping downwards, more like so:
6074.22 In reply to 6074.21
Thanks very much for the tips Michael.
I'll clean up some of the geometry and see how that goes, makes sense that 'wrinkles' would cause problems, not sure how I ended with them though.
With the tail-end I tried to Loft the tail the same as the nose (to an end point) but the Loft function didn't want to play ball. Actually the Lofts (on the four curves) seemed to be governed a little by the general happiness in the universe (ie: random) with a view change (zoom out seemed to help) sometimes causing the loft to succeed or not, but perhaps my swooping long-curves caused problems? I'll try the plan-off the end and see if I can then fillet it back to a softer 'cap'.
Will report how I go. Thanks also for the fold-over link I'll read that as well.
6074.23
Hello,
You could try a two rail sweep with some regularly spaced profiles. This seemed to result in smooth surfaces as opposed to some other methods I tried out.
Glider 2
Glider 1
EDITED: 3 Feb 2025 by OSTEXO
Which program is doing the zebra striping?
6074.25 In reply to 6074.1
argo, what is the purpose of such a large vertical stabilizer?
6074.26
Hello,
It's generated by the Lightlines feature in the VSR Shape Modeling plugin for Rhino 5.
6074.27 In reply to 6074.26
Thankyou.
6074.28 In reply to 6074.23
Hey that's very interesting OSTexo, thanks. I take it the rails are in the vertical plane when viewed from Front view? And the profiles are ellipses perpendicular to the rails?
Sort of on the same subject I came across MajikMike's MACH16 tutorial for a Networked organic shape. I tried it tonight and it gives great control as the control points can be manipulated, with the Networked solid following your changes - very cool. Only problem is getting the ends of the model smooth, as Networking used in this way is susceptible to non-tangent control points. I take it a two-rail system is not so sensitive at the tips?
Here's the tut if you have not seen it: http://moi3d.com/forum/messages.php?webtag=MOI&msg=5188.1
Thanks & cheers.
6074.29 In reply to 6074.25
Hey Chris
Not sure if you're a RC plane-nut like me, so sorry in advance if I write the obvious! This is a fuselage for a slope glider design affectionately called a "Plank". Its called this because its basically just a wing, often without a fuselage at all. I'll post a picture below of one of my favourite planks.
The reason the vertical stabiliser is so large is because its moment to CG (how far the fin is away from the centre of gravity - think of a lever) is short. This means there is very little lever-effect to keep the glider's yaw in check. End result is the glider tracks like its on rails with a decent setup including large fin. These are not slow gliders, the speed record for a type of gliding called Dynamic Soaring (DS) is approaching 500MPH - yep faster than a light aircraft. This sport uses the sheer-layers of air you get with wind as it crests a mountain slope.
And now you've got me rambling about my hobby :-)
The UberMoth:
Size: 124.4 KB, Downloaded: 53 times, Dimensions: 480x371px
Size: 97.2 KB, Downloaded: 39 times, Dimensions: 600x800px
6074.30
Hello,
Yes, that is correct. It also seems to work well when I tried out some lifting body sort of profiles instead of just ellipses. The two rail sweep gave a nice result as long as I made sure there was a profile set close to the nose to guide it properly. I fiddled around with moving the amount and position of the profiles and it seemed that an even distribution of profiles making sure that there were some close to the ends of the fuselage worked well. It takes a bit of work to get the curvature correct, but I found that Blending, Joining and Refitting the curves works. It is very easy to do this in Rhino+VSR but it can be done in MoI with a little more effort.
6074.31 In reply to 6074.29
I'm familiar with the distance of the surface from the CG and relation to the area required.
Because it increases the area, does it make motion from crosswinds more of an issue or am I missing something?
Perhaps because there is no fuselage that would also increase the area from the side profile, there really is not an overall increase in the area compare to a more "conventional" aircraft design?
6074.32 In reply to 6074.28
OSTexo just want to thank you for 2-Rail Sweep suggestion :-) I ended up using that method and it really was the easiest, plus it gave a surprising amount of control of the shape through-the-model via the profiles.
At the end of my build I tried to round-out (fillet) the interface between fin and fus, but its difficult geometry and in the end I was happy just to leave it. Below are images of the end product, its being printed in PLA and ABS plastics as I type. Printing required splitting it up so my print guy could get it on his print bed, plus hollowing it out saved some cash.
Cheers and thanks everyone for their advice and tips. Michael I'm singing MoI's praises to my fellow glider builders, you may see some more interest from this hobby segment :-)
BTW chrisd - good thinking on crosswinds affecting the big fin. I had to think about that one as the answer is no, but why? The reason I believe is that the glider flies WITH the airflow (wind), not in competition to it. This means there is no "crosswind" to a glider. The tail is there to fight the glider's inherent aerodynamic imperfections which are magnified by a wing-only ("plank") glider. As the wing moves through the air, imbalances cause see-sawing which the fin dampens out. Hope this off-the-top-of-my-head explanation makes sense.
6074.33
Hello argo,
Not a problem, I'm glad the suggestion worked out for the design. Is the fuselage shaped in that way to add lift or stability to the glider?
6074.34 In reply to 6074.33
Hi OSTexo
Other than the fin for yaw damping the fuselage has little impact on the aerodynamics of the glider (its all about the wing).
Smooth lines do however reduce parasitic drag of the interface between the fus and wing and also look cool :-) . Practically speaking the fus is there to: provide a tail to mount a vertical stabiliser (fin) to , and provide a nose to add lead to balance the glider around its CG (centre of gravity). Longer the nose the greater the leverage, so less weight required.
Cheers & tnx again.
Show messages:  1-14  15-34  35-40
