Trouble with Boolean Diff
All  1-5  6-8
5482.6 In reply to 5482.5
Hi
I Boolean Joined all the letters into 1 solid before flowing, and then the diff worked OK.. :)
I've noticed on the OSX version, when Display Hidden lines is unchecked, it still shows the hidden lines has solid lines..
5482.7 In reply to 5482.6
Hi steve, I'm glad you've got it working ok now.
I've just tested the OSX version and it seems to be working normally - try for example on a box and you should see the back edges of the box show or hide when you check or uncheck View > Display hidden lines.
But even with hidden lines turned off you can get "bleed through" which is a different issue, see here for more information on that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4987.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=4061.6
That's one of the various kinds of display artifacts that can happen with the real time display - because it's a big focus for the display to be fast there are a bunch of different kinds of imperfections that you can end up seeing in it that you would not see in an "offline render" type image.
5482.8 In reply to 5482.7
Hi Micheal
"Bleed Through" sounds like my problem, The Boolean diff leterrs are only .4mm deep.
Thanks again.
Show messages: All  1-5  6-8
