Thread cutting script - WIP
 1-15  …  36-55  56-75  76-95  96-110
5451.76 In reply to 5451.75
Hi Max,
thanks for sharing, very handy.
Do you plan in future to add into script countersunk head for different screwdrivers ( hex, torx, PH1, PH2)?
Mik
5451.77
very convenient - thanks
5451.78 In reply to 5451.74
Excellent script Max, written by a true scripting master. I'm impressed by the preview possibility and the speed. Very useful. Thanks.
-Martin
5451.79
NutsAndBolts.v.0.95
Bugs fixed
Added ASME B18.2.1/B18.2.2 dimensions
EDITED: 7 Mar 2022 by SMIRNOV
5451.80 In reply to 5451.79
Tremendous script!
I'm having a problem with the very first running of the script, either with ShortcutKey, or Ext. Script.
Here is the first result:
Selecting another size then works fine.
Is there some setting to change?
5451.81 In reply to 5451.80
Hi Brian, it's looks like a decimal separator problem. I never used decimal numbers as default values in my scripts before. So I didn't knew about this problem.
I'll fix it today evening.
5451.82 In reply to 5451.81
Thanks Max
A bit over my head but:
So it is something to do with regional settings, ...culture settings, ...locale settings...
...Parsing numbers with a comma decimal separator in JavaScript...
My Moi .ini file has Distance Display = Decimal under [units].
(I recently read of such a "bug," in Geomagic Design I think, which was corrected.)
5451.83 In reply to 5451.82
fixed
5451.84 In reply to 5451.83
"""""""""fixed""""""
confirmed.....
If you ever get into this again, an "enhancement request" would be a metric/imperial radio selection to limit the options container to one or the other.... Obviously not something "wrong", just a suggestion.
Thanks again Max for sharing...
5451.85
Thanks, Max. You are truly a wonder...
Wonderfully competent and wonderfully generous!
5451.86
This is brilliant!! Many thanks to Max.
How feasible is a Gear, Spring or bearing script? I think there is already a gear script out there but to have things like different tooth profiles and and bevel options and other related options would be something else. Something like this but for MOI - http://geargenerator.com
BTW I admire your generosity to the forum, but i can appreciate that this must take up considerable time. I personally would pay $10 - 20 for these highly developed scripts
Matt
5451.87
hi Max
this is such a need script. i wonder if you plan to add different heads like sucket cap or countersunk head for different screwdrivers ( hex, torx, PH1, PH2) in the future?
5451.88 In reply to 5451.87
hep
>> i wonder if you plan to add different heads like sucket cap or countersunk head for different screwdrivers (hex, torx, PH1, PH2) in the future?
Hi. At the moment I have no plans to continue developing it.
5451.89 In reply to 5451.88
Hi Max, ok - I like the script anyway :-)
5451.90
Amazing work.
I'll try to install it.
Guys...you're really great!
Thanks for all the job you're doing.
I love this community more and more everyday!
Moi and this community RULEZ
Arian DESIGN
www.arianshamil.com
5451.91
how do I install the script?
Thx,
Sven
5451.92 In reply to 5451.91
5451.93 In reply to 5451.91
Hi Sven,
Please see this new FAQ answer, it explains how to install plug-in scripts:
http://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
EDIT: Beaten by Max! :)
5451.94 In reply to 5451.93
Thx, I got it in meantime. Couldn't find the thread again... :-(
5451.95 In reply to 5451.74
Hi Max,
How did you make that awesome hatching effect on the side of the two blocks?
Show messages:  1-15  16-35  36-55  56-75  76-95  96-110
