Majik Primer: MoI's Lighting Options and You!
 1-19  20-39  40-59  60-69
5222.60
Added a simple configuration for basic Solid shading with no specular or shadows - great for graphics tracing of 3-D type and simple objects.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.6
5222.61 In reply to 5222.60
metallicLighting is shown as true in the script, and false in the picture. (This metallic setting does not seem to make any visual difference.)
For selection with CustomUI, I added the "Solid" lighting version to the custom LightingOptions.htm under ui.
It was necessary under MoI options, View, Lighting options, to update "Solid" selection.
5222.62 In reply to 5222.61
Got it, and thanks!
5222.63
Could someone please tell me in which system Folder the
personal favorites of lighting presets are stored ?
EDITED: 15 Nov 2017 by SIRTOM
5222.64 In reply to 5222.63
Hi Tom,
all the lighting presets are stored in moi.ini, including any personal favorites that you created.
That is located in <user>/Library/Application Support/Moi on a Mac. Not sure of the exact path for Windows.
Dinos
5222.65 In reply to 5222.63
For Windows, path is something like:
c:\Users\<user>\AppData\Roaming\Moi
You will have to select one of the User subdirectories to figure out the User name in <user>.
It should be the User subdirectory which contains AppData :-)
5222.66 In reply to 5222.65
For windows, click the start button and type
%APPDATA%
This opens that folder, then find folder "moi"
FYI: I keep my ini file in MoI's root installation folder. It will look there first, and keeps it more handy for the guy who wants it more often...
Michael also put a button for "edit ini" in the options panel, which finds and opens it for you. Havent tested that with the new beta yet though
5222.67
Thank you gentlemen, its always a pleasure to receive your quick help ;-)
Message 5222.68 deleted 15 Jun 2019 by PWWHDR70
5222.69 In reply to 5222.43
Thank you very much for this script. It is excellent :-)
Show messages:  1-19  20-39  40-59  60-69
