Majik Tutorial: Transitioned Recessed Surface
 1-5  6-25  26-45  46-47
4880.26 In reply to 4880.25
Thanks!
Mike
4880.27 In reply to 4880.20
Andrei,
I am still having trouble with this technique - any chance you could do your video in English? I've watched the Russian version for clues and read the post from Mike. But I am still not getting the results I want. It would be greatly appreciated! If not I understand, I am not sure where you guys find the time to do the magic you do to begin with!
John
4880.28 In reply to 4880.27
the video is exactly the same than the tutorial who begins here in English! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=4880.1
or here in French! ;)
http://moiscript.weebly.com/surfaces-2.html
I think that you must post the place and a file 3Dm where you are blocked!
PS @ Majikmike you have an error of link under the image "Surface Blending technic"
http://www.k4icy.com/tutorials.html
"http://www.k4icy.com/http//moi3d.com/forum/index.php?webtag=MOI&msg=4388.55"
EDITED: 30 Jul 2013 by PILOU
Problem in general with the Blend function arrives with these Side 1 and Side 2 !
Blend works in this case only if Side 1 and Side 2 are both "Edges" of the surfaces (here the rectangle and the recessed surface) and not any curves of construction!
A little trick is to read on the Info box up right corner when you select them!
if it's "Edge(s)" it's OK, if it's "Curve(s)" Blend will make nothing!
So delete or hide these "curves" of construction!
And Blend will works at each time! ;)
4880.30 In reply to 4880.28
Fixed... Merci Pilou. :-)
4880.31
Hay people,
Looks like nobody here showed this method yet, much faster and simpler:
Portfolio: www.samardac.tumblr.com
4880.32 In reply to 4880.31
Very convincing!
added! ;) (bottom page)
(if you are not the author of the concept tell me the name of him!
EDITED: 4 Oct 2013 by PILOU
4880.33 In reply to 4880.31
Very nice Andrei but I don't understand how in 0:50 of the video you condense/simplify the points of the cut surface so that you can later move them. Is it a command that you're typing ? if so which one is it?
4880.34 In reply to 4880.33
Niko, use this command to shrink surface: ShrinkTrimmedSrf
4880.35 In reply to 4880.34
Press Tab and write ShifrinkTrimmedSrf you don't want add a new shotcut!
4880.36 In reply to 4880.35
Thanks guys...thats a very powerful command...I think Michael should somehow stick it in the UI
4880.37 In reply to 4880.36
I can imagine dreaming up icons that represent some of these commands would leave Michael with a serious migraine, so perhaps we could convince him to just create a single icon of a treasure chest (or toy box?) that opens a list of the many many scripts and commands available but easily forgotten. At least easily forgotten by folks like me who only get back to the program periodically.
4880.38 In reply to 4880.37
I agree.
I do believe Michael has that idea on the list.
4880.39 In reply to 4880.38
me too :)
4880.40 In reply to 4880.1
Hey Mike - everyone,
Any chance of refurbishing this tutorial; pretty hard to follow without the pictures.
I'd be very grateful!
Moi Bueno
MindSet
4880.41 In reply to 4880.40
What tutorial ? This one ?
Seems there are some images! https://moiscript.weebly.com/surfaces-2.html
My Moi French Site
4880.42 In reply to 4880.40
Hi MindSet,
The images seem to be there at:
Where are you seeing missing pictures?
4880.43 In reply to 4880.40
Hi MindSet, looks like the linked images won't display if you use https:// to view the tutorial page.
If you use http:// then it's ok. But some web browsers don't support http:// anymore. Firefox does.
4880.44 In reply to 4880.43
Thank you one and all!!
Brilliant!! Wonderful! Marvelous!
This really helps.
Good to know about the FireFox trick too.
Pilou, I told all my American friends that French is a real Language and that other countries do actually exist!
But none of them believed that I have friends, imaginary or otherwise.
Again, thanks everyone!
Happy New Year
EDITED: 1 Jan 2025 by IGNITER
4880.45 In reply to 4880.44
@Mindset
Happy new year to you...and seems we are maybe not on the same planet! :)
Show messages:  1-5  6-25  26-45  46-47
