New Mac OSX public beta Jan-31-2012 available now
 1-14  …  55-74  75-94  95-103
4879.95 In reply to 4879.94
Hi blankidea,
> Thanks again for your tip. Works great a few second and
> the boolean operation was done. Even if I don't know
> what the operation does...
Check out here for some more general information on how "underlying surfaces" work with NURBS objects:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
But it might be better if boolean union used some different method to get the bounding box rather than one that included the full underlying surface size - the reason why it uses that one right now is because it's very quick to get it.
4879.96 In reply to 4879.95
Hi Michael Gibson,
By the way I forgot to tell you that CMD+V does not work on the input fields.
I use the script to get the "length of a curve" and try to paste the value into the input field.
Only the right mouse button work, but you also loose the size because you change it when you come back with the mouse
into the drawing viewport.
Also I install a script called (redefine Curve) which I have to install directly into the application (by right click on the app icon "show content").
Normally you use the Library folder for the user but this one is not working.
Thanks for your overwhelming support :-)
4879.97 In reply to 4879.96
Hi blankidea,
> the input fields.
For the moment use the Ctrl key instead with Ctrl+V and it should work, but that is something that I will fix up for the next beta to make Cmd+V work for text pasting like you were expecting.
This part probably won't change for the 2.5 release - it's the same with the Windows version where you install scripts into the application's commands sub-folder and not into a centralized location like the Library folder. I do want to improve this in the future to work like that but I do not expect for that to make it into the 2.5 release though.
So to install a plug-in command into OSX MoI now you will need to right-click on the app icon and then pick "Show package contents", then go to drive_c/moi/commands - that's the place where you will need to copy plug-in command to in order for MoI to recognize them.
In the future I want to overhaul the whole plug-in installation process so that there will be some kind of UI that handles it for you and you won't need to drill into specific folders but that's how it works currently.
Thanks for the additional bug reports!
4879.98
first of all a BIG THANK YOU for providing this OSX-Beta! Unfortunately I was kept very busy the last 2 months preventing me to test drive and give comments earlier... but finally...
It runs quite well even on my old MacBook with the problematic GMA X3100 graphics chip. A bit slow for more complex projects, but this is really more than I thought with this "old 2D-card".
Apart from the already mentioned slow resizing and incomplete filling on initial application's opening (see screenshot) I only found one additional thing: the icons for the new deform tools don't show up. But taking a closer look I guess you just haven't cooked them up yet... :)
I really enjoy playing with MOI and look forward to running the final release on some newer Mac hardware....
Again thanks for this great program!
Chyman
Size: 115.1 KB, Downloaded: 90 times, Dimensions: 1280x774px
4879.99 In reply to 4879.98
Hi Chyman, thanks for testing it!
That's great news! But yes this card just does not fundamentally have the same amount of GPU horsepower as nVidia or ATI cards, so you may only be able to get to a medium level of complexity with it. But you should actually be able to get quite a lot of projects done with it, especially if you only deal with different parts of the project at a time instead of everything all in one single big model.
Also if things start to bog down on a more detailed model, try adjusting the "Mesh angle" settings under Options > View as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4643.2
Setting the "Mesh angle" to a rougher angle like 25 degrees and unchecking "Add detail to inflections" will make for a somewhat rougher looking display but also lighten up the density of the display meshes and that can help boost display performance by quite a bit.
Yeah this is one of the last areas that I have remaining to work on before releasing a new beta.
This one I hope will be solved by some updates and bug fixes to the Wineskin system that will also be included in the next beta, but I'm not entirely sure. Please let me know if you see it again with the next beta when it is out.
Yup, that's normal for the time being - those tools are new for v3 and still need a bit of attention to be finished up. Finishing that area will probably be the last step before rolling out a final 2.5 OSX version, it won't be quite finished still for the next beta.
But I'm glad that MoI OSX is able to run on those Intel graphics cards now, I wasn't sure at first if that was going to be possible. But also someone else has tested it on the oldest GMA 950 and it works there too now, so MoI OSX should work on all Intel Macs I think, including the very first ones.
4879.100 In reply to 4879.99
Thank you for your comments and the "Mesh angle" hint (that is a good performance parameter).
Indeed your OSX support turned out quite complete after all, well done!
Hope I can come up with some nice output soon...
Chyman
4879.101
I have "MoI v3.2 trial.app" in my Applications folder. When I run MOI I get
"ERROR! cannot write to info.plist, there are permission problems, or you are on a read-only volume.
This cannot run from within a read-only dmg file."
What do I need to do?
Is there a search function for this forum?
4879.102 In reply to 4879.101
I have found the search feature.
I have found previous posts that describe my exact error message. However, they suggest a fix I have already done. So, I still need help. Is there a trial of version 4?
4879.103 In reply to 4879.101
Hi statfi,
This is due to a new security mechanism in recent Mac OS versions that forces app bundles to be read only if they have the "quarantine" flag set on them which they will if they have been downloaded. This interferes with MoI v3's operation, resulting in this particular error message. Usually this happens if you try to run it directly from the Downloads folder and goes away if you move the app over into the /Applications folder. But it's a fairly brittle mechanism, the operating system will only clear the flag if you move it using drag/drop in Finder, not if you move it by some other means like by command line. Is it possible that applies to how you moved it?
The security mechanism is called Gatekeeper path randomization and there is some more information on it here:
https://weblog.rogueamoeba.com/2016/06/29/sierra-and-gatekeeper-path-randomization/
Another way you can probably solve it is by manually removing the quarantine extended attribute from the app, like this:
https://derflounder.wordpress.com/2012/11/20/clearing-the-quarantine-extended-attribute-from-downloaded-applications/
This won't happen anymore in v4, the Mac version for MoI v4 has been significantly rewritten and restructured so it no longer needs to modify the app bundle's info.plist file and isn't troubled by being read only. Currently v4 is in beta release available to existing v3 users. There won't be a trial version of it until it's finished and the final release is available. I'm not exactly sure when that will be yet, maybe something like Fall this year.
Show messages:  1-14  …  35-54  55-74  75-94  95-103
