 1-14  15-34  35-54  55-74  75-94  95-114  …  3115-3117
4446.55 In reply to 4446.53
Great info, thanks Frenchy
Do you ever sleep? ... seems like you are always coming up with new stuff.
4446.56 In reply to 4446.55
Some insomiac indeed! :)
Hi Pilou!
I don't remember if you have already reported this web app, but if not,
I think you'll find rather interesting these great 3d web app from Stéphane GINIER (https://stephaneginier.com/) :
https://stephaneginier.com/archive/editSDF/
https://stephaneginier.com/sculptgl/
See you!
Marco (mkdm)
4446.58 In reply to 4446.57
Excellent alternative to the free Sculptris http://pixologic.com/sculptris/
About the incredible online https://stephaneginier.com/archive/editSDF/
you must press the button "Apply" for validate a primitive before call a new one!
EDITED: 2 Jun 2017 by PILOU
4446.60 In reply to 4446.59
Hi Pilou!
Yes...I already know.
But I don't know how to export in obj format. it seems that it's available only a strange "glsl" (OpenGL) format,
and I don't know how to use it in order to import the geometry data into other software.
Do you know more ?
Thanks.
Marco (mkdm)
Hi Pilou and everyone.
WOOOOOOOWWWW !!
Found this : https://www.shadertoy.com/
I didn't know it. it can load "glsl" Pixel Shader file generated from "https://stephaneginier.com/archive/editSDF/" !
From its About page : "Shadertoy is the first application to allow developers all over the globe to push pixels from code to screen using WebGL since 2009."
And from Stackoverflow :
"ShaderToy is a tool for writing pixel shaders."
Look at this : http://pixelshaders.com/
It seems to be very very interesting...
See you.
Marco (mkdm)
P.S. See this video article : https://www.youtube.com/watch?v=TDZMSozKZ20
EDITED: 2 Jun 2017 by MKDM
Hi Pilou.
Look also at this! It's awesome on my 1080 Ti : https://www.shadertoy.com/view/llK3Dy
Ciao!
About the json format :)
there are some converters on line http://codebeautify.org/jsonviewer
alas the xlm resulting can't be reloaded inside Kerkythea (the only one for the moment that I remember that reload xlm file! :)
I believe that with Processing (a free coding program, you can reload json file format with some library installed and save as obj)
but i want find more simple! :)
In any case json format is reloaded by the editSDF itself!
4446.65 In reply to 4446.63
Shadertoy
Sure sound + crazy images & shaders that is hyper cool!
(but seems little codes must be done ? ;)
Minutes 1.06- 1.26 of your link!
4446.66 In reply to 4446.65
Ah ah ah....very funny this one. Look : https://www.shadertoy.com/view/XsBXWt
All in realtime on GPU!
@You : "...but seems little codes must be done ?..."
Oh yeah!! A lot of code.
But I totally don't know that programming language and math or OpenGL shaders aren't in my programming kwnoledge :)
(I write business app for android/ios)
It's only funny for me to watch how these guys are able to push out from GPU :)
See you.
4446.67 In reply to 4446.65
Oh my God! I can't stop watching that stuff!!
Pilou, look at this insane and amazing realtime video : https://www.shadertoy.com/view/4dlyWX
Amazing!!!
OK. Over and out!
Ciao.
I believe that Unity can import json file! ;)
Alas I must reload unity for test that because the new update of Windows 10 invalidate my previous licence!
Relaoded but...
Not trivial for json, xml, so...good luck! :)
4446.69 In reply to 4446.68
Thanks a lot Pilou for the info.
But...what about Unreal Engine and Json ?
I'm trying to use UE instead Unity....
Thanks.
4446.70 In reply to 4446.69
Must be possible as like! ;)
Else with SDF :)
4446.71 In reply to 4446.69
@Marco
http://www.mediafire.com/file/0oynrpi11opvkm7/OBJ+and+JSON+Converter+Program+2.0.zip
Features:
* Drag and drop support on executable.
* Easy to use program.
* Converts OBJ to JSON
* Converts (converted)JSON to OBJ
Recommended:
Windows 2000, XP, Vista, Win7
Alas for me during the convert "the Convertor has stopped to work" ... (surelly because I have Windows 10! :(
So a convertor on line (if existing) will be the solution!
EDITED: 3 Jun 2017 by PILOU
4446.72
Cool Beans!
I am amazed at the realtime nature of these. I have 2 Nvidia cards, I wonder if it uses both?
I really like this one:
https://www.shadertoy.com/view/4sXBRn
You can use your mouse to navigate the window. My display is set at 3440x1440 and it's stunning full screen. Thanks for sharing!
4446.73 In reply to 4446.72
Hi Chipp.
@You : "...I am amazed at the realtime nature of these...."
Yeah...It's amazing how stunning are the visual results of most of the shaders of shadertoy.com!!!
I don'have a dual nvidia card in SLI but a single Gtx 1080 Ti on a very poor FullHD screen
but the results are absolutely amazing!!
I wonder how the performance could be even better with a Gsync QHD or 4K monitor.
i really love this one : https://www.shadertoy.com/view/MscXzn
It has slider to control the effects.
See you.
Shader online https://stephaneginier.com/archive/editSDF/
Like a fractal landscape in a second :)
So with Paint 3D on fbx moi's files...
EDITED: 6 Jun 2017 by PILOU
Show messages:  1-14  15-34  35-54  55-74  75-94  95-114  115-134  …  3115-3117
