 1-12  …  393-412  413-432  433-452  453-472  473-492  …  3113-3119
4446.433 In reply to 4446.431
Thanks Frenchy for the nice link in CG Society. That original video was the impetus for masterxeon1001 to implement his own version of kitbashing in Hard Ops a year or so before I ever met him:
https://masterxeon1001.com/2016/01/05/hops0065update/
4446.434 In reply to 4446.433
@Chipp
You are also in the biggest 3D French portal ! ;)
http://www.3dvf.com/actualite-24581-kit-ops-un-addon-blender-kitbashing.html
EDITED: 22 Oct 2018 by PILOU
4446.435 In reply to 4446.434
Wonderful! Many thanks
Magica buildings :)
4446.437 In reply to 4446.436
Beatiful!
Citizen Kane! ;)
My Moi French Site My Gallery
4446.439 In reply to 4446.432
Hi Might be wrong place to post this but I thought it would be something mkdm would like https://www.youtube.com/watch?v=vtnJToPxBNo
Keith
EDITED: 25 Oct 2018 by PILOU
4446.441 In reply to 4446.439
Thanks Keith!
Yes :) You nailed it!
Very interesting.
Asap I'm going to check it!
4446.442 In reply to 4446.440
Wonderful gallery!!
I like it very much!
Bravo :)
Some amazing indeed!
4446.444 In reply to 4446.443
Amazing things!
I can't wait to see the first final public release of Blender 2.8!
4446.445 In reply to 4446.444
I believe you can use the 2.8 for test it! ;)
""These builds use the latest snippets of magic code developers write. Give the upcoming Blender 2.8x a try! Although it is absolutely not recommended for use on production environments""
4446.446 In reply to 4446.445
Well...indeed, it could be a very interesting thing, but this period really no spare time to deserve to beta testing :)
Almost zero.
Tree Generator (free) TreeIt
http://www.evolved-software.com/treeit/treeit (7 Nov 2018)
EDITED: 8 Nov 2018 by PILOU
Magica
How erase a line(s) with just one click ?
not works here
All functions can be pressed on the screen but very speedy with SHortCuts!
T + F + Ctrl+2 + Shift + Click
aTtach  + Face + SHIFT + Axe(s) +  Click (Shift is a trick for keep the creation mode but this invert it)
you must know the axe of it : easy because there is a tripod RVB on the bottom righ of the screen
So Axe Y [b]key on the screen or (CTRL + 2) because shortcut y is yet for other thing!
@stefan
there is a new plugin by Zarbuz for Magicavoxel! https://github.com/Zarbuz/SchematicToVox/releases
You can enter any image under 2048 * 2048 (4096 * 4096 will works but will be truncated)
Each matrix will be 126 * 126 *126 and image automatically trimed !
Little bad side it's line commands! So for Windows 10 : Logo windows + R and enter the following line
if your image PNG is on the same folder (and with 255 colors max - black colors up palett are error by my fault! ;)
C:\Users\Pilou\Downloads\SchematicToVox-v1.0\SchematicToVox.exe --i toto.png --o totovox
will be the same for an object format schematic (Minecraft) not yet tested but i believe there will be only one color!
my test with a little image of Verve! ;)
EDITED: 10 Nov 2018 by PILOU
so inside Magicavoxel by Zarbuz! ;)
Blender becomes more human! :) (but it's 20$ )
(you can put video speed *2 )
And I beleive that "Companion" is inside the Above
EDITED: 15 Nov 2018 by PILOU
Before an hypothetic shader in Magica :)
Curiously the shader xs height works better with color image than gry levels from this same image color :)
Show messages:  1-12  …  373-392  393-412  413-432  433-452  453-472  473-492  493-512  …  3113-3119
