 1-18  …  219-238  239-258  259-278  279-298  299-318  …  3099-3117
...and this one : https://demo.marpi.pl/
Html5 and WebGL to the max!!!!!
Ciao :)
4446.260
Thanks guys! Great stuff!!!
Unlimited amazing exploration!
The good point is the experiment in direct online!
The bad point is the necessary time to integrate code learning! :)
Java Script + Html ?
My Moi French Site My Gallery
4446.262 In reply to 4446.261
@You : "..Java Script + Html ?..."
All that stuff are : WebGL + HTML5
Amazing! Some of that tools are useful also for export things in vector or 3D format that you can use in other software like Moi or any Affinity Designer.
Amazing.
4446.263 In reply to 4446.262
Yes that cool but need to learn some new tools...
I see something like p5.js make the same but is 3 times less speed than classic Processing...
In any case amazing tools for "big heads"! :)
A cool guy : https://www.youtube.com/user/shiffman/videos
4446.264
Cool stuff guys! Keep those links coming to keep me distracted from work. :)
Regards,
— Metin
visualization • pixel art • illustration • 3D design — https://metinseven.com
4446.265 In reply to 4446.264
@You "...Keep those links coming to keep me distracted from work. :)..."
LOL :)
I'm a single person company....I'm on the verge of fire myself :) :)
4446.266 In reply to 4446.265
:D
I'm also a one-man company. But a little distraction between working sessions is essential to keep your concentration intact.
Regards,
— Metin
4446.267 In reply to 4446.266
LOL :)
You're right Metin!
...the hard life of a one-man company :) :) :) :)
Ciao!
4446.268 In reply to 4446.267
Heheheh! ;)
Regards,
— Metin
Hello everyone!
Do you know "Neobarok" ?
It's author is engaged into the advanced alpha stage of version 2.0
Amazing things are around the corner...
Just a little taste :
https://youtu.be/0s8Mx4-qYtU
https://youtu.be/HpH2BgwssiM
https://neobarok.com/
https://www.facebook.com/neobarok3d/
Ciao!
PolyBrush, NeoBarok, MeshMixer...we are submerged! :)
https://neobarok.wordpress.com
Baffling! Remember the regreated Groboto in some aspects!
EDITED: 6 Mar 2018 by PILOU
Hi Pilou!
I apologize if I use this channel to ask you something specific, but I don't want to send PM.
Just out of curiosity : Are you still supporting the beta testing of R3F ?
Many interesting things has happened there.
In this period I've supported Istonia/Samardac with a huge testing phase, still not finished.
Now R3F has become even more a very good, low cost, companion for Moi.
It now has a very powerful "Take Snaphsot" command also with the chance to generate AO.
Ok, a very simple version of AO, but for quick image composition purposes in super high resolution (up to 16K) is more than enough.
If you want check the last post of this thread :
https://www.rocket3f.com/kunena/helpme/447-capture-r3f-s-viewport-in-custom-hi-res-resolution
Ciao!
4446.272 In reply to 4446.271
<< Are you still supporting the beta testing of R3F
Of course yes but alas no time to use and test it for the moment! :(
I maintain the French part of the forum when a new version is stable!
I pass all days on the forum and seen the AO adventure testing... :)
4446.273 In reply to 4446.272
@You ; "...Of course yes ..."
OK. Good to know!
I've decided in this period to help those guys (Istonia/Samardac) with my experience in image composition to make R3F even better.
Still work in progress... ;)
4446.274 In reply to 4446.224
Hi Pilou
There is also a free plugin for older versions of PhotoShop that converts to DDS
https://developer.nvidia.com/nvidia-texture-tools-adobe-photoshop
Best wishes
Keith
4446.275 In reply to 4446.274
Cool for Toshop users but I am not user of Toshop! ;)
4446.276
Designspark Mechanical has great filleting abilities, so it would be good to have a way to make it cooperate with Moi. But DM does not export to nurbs files (IGES or STEP) and so there is a problem in importing from there to Moi. Any solution to this problem?
4446.277 In reply to 4446.276
<< problem in importing from there to Moi. Any solution to this problem?
Seems you have not seen my little post about that! ;)
Take me five minutes for refind it! ;)
Ok Refound! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6186.32
in this marvelous thread where there another a lot of true gems! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
You have the complete solution in French here : http://moiscript.weebly.com/designspark-1.html
"Traiter les congés récalcitrant de MOI!"
give me 10 minutes for detailed it in English :)
Ok :)
Dealing with recalcitrant fillets from Moi!
Importing a Step object into DesignSpark Mechanical V1 (DMS)
Process the difficult fillets and then send the object back to MOi!
To do this, in DesignS save in the normal DSM format (MyObject.rsdoc)
Rename to MyObject.zip
Unzip: we have a.sab file in the SpaceClaim / Geometry folder of the dzipped folder
(in the arborescence of the folder file unziped)
Find the SabSatConverter.exe file address in the DSM directory of the original program
(in Windows to know the address of a file do Right Click + Shift on this file)
With these addresses one can fill the line of the "Windows Executor"!
You get something like that (one command line)
"C:\Program Files\DesignSpark\DesignSpark Mechanical 1.0\SabSatConverter.exe" -i "C:\Users\Desktop\MyObject.sab" -o "C:\Users\Desktop\MyObject.sat"
If it doesn't work we can try this!
You can add at the end of line -v with a parameter going from 4 to 24 for the headers of the different versions.
It seems -v 8 is the most operational!
Press Enter and the file MyObject.sat is created! Just import it into Moi!
That all : a bit tricky but working!
The key is run DesignSpark 1!!!
EDITED: 16 Apr 2018 by PILOU
Show messages:  1-18  …  199-218  219-238  239-258  259-278  279-298  299-318  319-338  …  3099-3117
