 1-18  …  79-98  99-118  119-138  139-158  159-178  …  3099-3117
4446.119 In reply to 4446.118
That's exciting news, thanks for the update, Michael!
— Metin
metinseven.com — visualization • illustration • animation • 3D (print) design
4446.120 In reply to 4446.113
Thanks Metin for the helpful list. Much appreciated!
4446.121 In reply to 4446.120
My pleasure, Chipp. Thank you for your very informative tutorials.
I'm still exploring 3D Coat, and I love it more every day, especially the voxel sculpting mode. It offers the highest level of sculpting freedom I've experienced so far.
Regards,
— Metin
4446.122 In reply to 4446.121
Hi Metin!
@You : "...especially the voxel sculpting mode..."
Don't forget to discover all the great and powerful opportunities offered by "Surface mode" and "Clay brushes" also!
Ciao!
4446.123 In reply to 4446.122
Hi Marco,
Yes, exploring Surface sculpting — including Live Clay — is high on my 3D Coat to-do list, although I've already messed around with it a bit. Promising!
Regards,
Metin
4446.124 In reply to 4446.118
Hi Metin, well my extra week after the end of the month is almost up and I'm still not quite ready but it's awfully close. I just finished up getting everything except text labels (which I'm leaving out for the first release) drawn and so the only remaining thing is some work on shaders for shaded surfaces and line drawing. If it looks like it might take a while I guess I could leave the line drawing ugly for the first release.
4446.125 In reply to 4446.124
Hi Michael
Will all the scripts that people have created work with version 4? I have become attached to them.
BW
Keith
4446.126 In reply to 4446.125
Hi Keith, yes it is intended that V3 scripts should work with V4. For a few scripts its possible some tune ups in MoI will be needed or possibly a couple of lines of the script might need to be altered but I think that shouldn't be very common. Once the v4 beta is out please let me know if you find any scripts that don't work.
4446.127 In reply to 4446.126
Can we use the moi.ini V3 for beta V4 ? or copy / paste ?
It would be great if i could keep all my shortcut keys.
4446.128 In reply to 4446.127
Hi Finema, MoI v4 uses the same moi.ini file as MoI v3, by default the moi.ini file is created in a shared location in %AppData%\Moi on Windows or ~/Library/Application Support/Moi on Mac and all versions of MoI share the same one moi.ini file.
So unless you've customized the moi.ini file location (which can be done by moving it into the same folder as the MoI.exe or by giving a command line parameter with a path to the moi.ini file when MoI.exe starts up), V4 will use the same moi.ini file and have the same settings and shortcut keys as V3.
4446.129 In reply to 4446.128
Yes ! very cool !
I can't wait to test it.
Thanks Michael.
4446.130 In reply to 4446.124
Hi Michael.
@You : "...I just finished up getting everything except text labels (which I'm leaving out for the first release)..."
What's this "text labels" you are referring to ?
@You : "...If it looks like it might take a while I guess I could leave the line drawing ugly for the first release..."
I think this shouldn't be a problem :)
Have a nice day.
4446.131 In reply to 4446.130
Hi Marco,
It's the little tag labels that show up on snap points like "End" or "End, Mid, Cen, Int" that tell you the type of snap that's engaged when you're picking points.
It will be coming back, it just won't be in the first beta release. Text can be kind of complicated in 3D accelerated graphics there isn't just one built in way to do it there are a variety of different methods with different trade-offs.
4446.132 In reply to 4446.131
Thanks for the info Michael.
@You : "...Text can be kind of complicated in 3D accelerated graphics there isn't just one built in way to do it there are a variety of different methods with different trade-offs..."
I understand. No problem.
Ciao!
Hi Metin, Chipp or Marco
i looked up the 3DCoat site on how to mask (flat) areas of a surface and found a thread there which is unfortunately closed.
@Metin have you found already a way to mask with automatic fill (in my case flat areas) so that you can refine
unmasked sculpted areas? In ZBrush this is super easy, but when i try this in 3DCoat (because i like to try out something
there too) i don't know how to do it. I first thought to do it in the paint room, with fill and freeze activated, bit it fills
the whole area, even if i set it to convex or concave or flat etc. ... :-(
In case you guys have a solution i would be quite happy.
My attached pic shows what i mean, i used the Tiger from freepik.com, cleaned it up in MoI and then used
the region-relief tool on the parts with ArtForm Pro 4.0 and finally brought the model into ZBrush for auto masking
and refining the non-masked areas.
(dark brown areas are the auto masked areas)
4446.134 In reply to 4446.133
Hi Stefan!
@You : "...Looked up the 3DCoat site on how to mask (flat) areas of a surface...@
I'm not sure I understand well, but there are in 3DCoat at least a couple of main tools that you can use to "mask" areas :
1) "Vox Hide" in Voxel Mode
2) "Freeze" in Surface Mode
Both tools work in tandem with the "Freeze" and "Geometry" menu :
You can use these commands to perform very sophisticated editing of voxels/surfaces
Here's a very basic and rough example on how to use the "Freeze" tool to "mask" flat areas.
The key is to switch from perspective to "orthographic" view.
The video : http://take.ms/sULSP
But I don't know if I understood your question correctly :)
Let me know.
Ciao!
Marco (mkdm)
Hi Marco,
thanks a lot for your help! This is what i mean! Is this also somehow possible
when let's say the model is not flat and you have raised areas and want to mask
the lower areas (in an automated way, without painting with brushes) ?
Best regards
4446.136
Interesting indeed, thanks Marco! I still have to dive into the Freeze functions.
— Metin
4446.137 In reply to 4446.135
Hi Stefan.
You're welcome!
@You : "...Is this also somehow possible ...(in an automated way, without painting with brushes) ?"
Well...this is a bit tricky I think!
For what I know there's no completely automation for this kind of things in 3DCoat.
But one of the things that you can try and that is semi-automated, is using one specific tool in "Paint Room"
That tool will allow you to decide on what "kind" of surface you want to paint on (or freeze).
This is a very coarse and rough tutorial I made on the fly : http://take.ms/wjnlsC
You can start with it and make practicing on that tool.
Ciao!
4446.138 In reply to 4446.136
You're welcome Metin.
Ciao!
Show messages:  1-18  …  59-78  79-98  99-118  119-138  139-158  159-178  179-198  …  3099-3117
