Mark's Ships
 1-5  6-25  26-33
4184.26
Hi Al,
Sorry for the slow reply. I have been messing about with your excellent water texture.
I used the dielectric material I've used for water previously as the starting point for using the textures. After experimenting for a while I decided on both colour textures in the refraction channel plus bump. The normal map didn't seem to play well with the dielectric material so I left it out for the time being.
I would be very happy to have more like it if you don't mind doing them. Something to give a North Atlantic stormy look would be very nice.
Here are renders of HMAS Perth I with the unusual unfinished paint job she was wearing when lost, as well as Sydney rendered in KT with your water textures:
Mark
Size: 300.3 KB, Downloaded: 43 times, Dimensions: 1366x768px
Size: 235.5 KB, Downloaded: 87 times, Dimensions: 1366x768px
Size: 173.5 KB, Downloaded: 22 times, Dimensions: 1366x768px
Size: 140.8 KB, Downloaded: 22 times, Dimensions: 1366x768px
Size: 210.8 KB, Downloaded: 24 times, Dimensions: 1366x768px
Size: 721 KB, Downloaded: 89 times, Dimensions: 1366x768px
4184.27 In reply to 4184.22
Hi David,
Sorry to hear about your laptop. Even worse is hearing that you lost some of your work. That is always heartbreaking!
I tried exactly the same thing with VirtualBox on a Linux netbook. In the end I just had to accept that the DirectX emulation in VirtualBox is too immature to run MoI. Instead, I managed to install Windows XP on a USB stick and booted from there. More trouble than it was worth really but it did work. I think though that installing Windows in another partition on your Linux box is a better option.
The Ocean Sim and that 'Dynamic Paint' build are both very interesting additions to the new Blender. I'm also thinking about taking another look at Terragen and a first look at Mojoworld. Povray also seems to have come a long way since I last tried it.
So many interesting possibilities.
Mark
4184.28 In reply to 4184.24
Paq, sorry to read on your page that your employer shut up shop. It will be somebody's lucky day to snap you up. I've always thought the work you've shown here is something special. The gallery on your blog page is incredible! You are a seriously talented 3D artist.
Thanks to both you and Jim and everyone who has commented so kindly about these models. I'll finish all this off with some Simlab renders of Yarra in a day or two. Then I think I'll take a break from modelling to do some coding. I'm a terrible programmer but I find it relaxing....
Mark
4184.29 In reply to 4184.23
Yes, the low polygon budget was a real challenge. I don't know exactly why they set such a low target, which in the end I failed to achieve. Some of the battles they want to simulate had quite a lot of ships involved so perhaps the number of models on screen plus the need to simulate the ocean, smoke etc was a factor in that. One would hope though that the Navy has a fair bit of rendering power at its disposal!
Mark
4184.30
Hi Mark,
It looks like using your dielectric material and both textures came out really realistic. I'm very glad you could use them. I think your renders are always awesome, and I'm flattered that I could contribute something that you could use. I'll have a think on how best to do stormy North Atlantic. Were you able to use the height map for displacement?
So basically you would need one or two layers for color channels (or maybe three because of the whitecaps) and a height map for displacement?
Al
EDIT: I went ahead and removed the textures since you have them already.
EDITED: 18 Apr 2011 by OMAC12
4184.31
Your models are an inspiration Mark!
4184.32
Fantastic models, I can tell you are very passionate about these boats. Ships. :)
I am curious as to how Moi handled such detailed objects. I haven't been sure if it's my particular machine or not but Moi get's pretty bogged down with things even half as complex as these for me.
Did you model them all in one file or did you break them up into separate files?
I am interested for the methods for the Hull with Moi
http://moi3d.com/forum/messages.php?webtag=MOI&msg=4222.1
Show messages:  1-5  6-25  26-33
