Beveled Text
 1-10  11-30  31-50  51
3723.31 In reply to 3723.30
Hi Pilou, yes that's normal - the forum only resizes image elements and the video is an iframe element, not an image element.
You can also view it at:
https://www.screencast.com/users/MoI/folders/Camtasia%20Studio/media/5d54cfd1-206a-449a-ba84-cd9f40e4f6c7
that one will have a "full screen" control in the lower right corner, I think it should fit it to your monitor size.
3723.32 In reply to 3723.31
Yep this time that is perfect!
3723.33 In reply to 3723.32
Few good tips here...
https://youtu.be/L1hhZ0_7gP8
3723.34 In reply to 3723.21
With combo tools:
3723.35 In reply to 3723.34
Nice one Burrman! I need to take a look at viacad.
Was also considering a potential 'type and go'
route from aspire or v-carve. They call it 'prism text' for seperate shapes.
Export as stl?
https://youtu.be/5tq45xBitXopl
I noticed on youtube you might use Bobcad/cam is there a route that way?
[Obviously once tool paths set up for certain letter thicknesses it should be quick.]
- stefano
EDITED: 1 Oct 2020 by LIGHTWAVE
Another tracks with Blend curves so you can take any Bulge you want...so less or more elegant result! :)
Sweep or NetWork for the long Part
Sweep or NetWork for the Foot
Planar for the triangle
PS I don't know if the Gray Thema by Cody is less or more readable than the original UI ?
EDITED: 30 Sep 2020 by PILOU
3723.37 In reply to 3723.36
muscle memory test...~23 seconds...
3723.38 In reply to 3723.35
"""""I noticed on youtube you might use Bobcad/cam is there a route that way?"""""
For actually manufacturing it, yes... a toolpath that cuts that from fonts/pockets.
Can export a simulation of the cut as stl too.
But not model it for visual. (Differently than Michael showed)
EDITED: 1 Oct 2020 by BURRMAN
3723.39 In reply to 3723.38
Hi Stefano,
Took a quick look at the Vectric stuff (aspire) and it looks like they offer the toolpath option too. So it's not "type out text" like that. It's a toolpath called "v-caving"....
The other thing these CAM packages like Vectric Aspire or BobCad have is "embossing".
So in BobCad, they have "BobArt" and i can emboss geometry using arcs and lines and angles, which produces this too....
But the result of these will be poly's, not NURBS.
3723.40 In reply to 3723.39
Hi Burrman,
Was just thinking the approach of Michael's is great on single letters or a few letters
...but what about if there is a whole paragraph of text where many of the letters could be
quite small?
Points noted about STL* and I've discounted that route...
so now wondering, could a bitmap>3d route work nice e.g.
max's heightmap?
Greyscale bitmaps of some "I" files attached. This was sent to me from one of the technical
guys at Cadlink Engravelab/Signlab software. They don't do stl but do can do
bitmaps of toolpaths easy and fast...
As I don't have heightmap installed and had issues knowing where to install it, hoping someone can try...
Stefano
*STL thread here if anyone interested: http://moi3d.com/forum/messages.php?webtag=MOI&msg=8860.1
<< but what about if there is a whole paragraph of text where many of the letters could be
quite small?
Just make one alphabet with your font wished! ;)
So you can write any text at any size!
3723.42 In reply to 3723.40
""""""but what about if there is a whole paragraph of text where many of the letters could be
quite small?""""
I think you just need to move into poly apps. Just about ALL of them just do chisel text naturally...
Heightmap route wont give you very crisp results and i believe you would run into the same thing. Parts will be hard to achieve. Just look at a capital N in the times new roman and look at michaels solution against it...
You could make an attempt as frenchy said and take a month to model every charactor of the times new roman uoper and lower case.
But "paragraphs" would still be pretty tedious...
3723.43 In reply to 3723.42
Frenchy & Burrman,
Thanks for your feedback. I like some of the workflow here
http://www.rushfx.net/chisel-type-using-spline-fields-in-cinema-4d-from-cineversity/
(Slightly out of budget)
Maybe you can use the free Fusion 360 and export as Step format for MOI? ;)
But alas you must "draw it" first as in Moi! --- maybe with more easy Fillets...not sure in this case... :)
I just made here the beginning :D (then imported as Step in Moi)
EDITED: 1 Oct 2020 by PILOU
3723.45
It's possible in Moi using sweep but requires splitting profile into sections and in some cases extending them.
Trimming is tricky but I used Michael's FlowExtendSurf script in places to help with this.
Barry
For MoI serif font Times New Roman, used the sweep technique with two 45 degree lines, for D and R. Manual trimming required. Did C with Merge. The 3d letters look good.
3723.48 In reply to 3723.46
Cheers chaps will take a look at some of these routes but not likely to dive into fusion at moment.
Unless it's easy to get a finished result...
@Brian- I presume setting the 45degree line at a length greater than the widest 'stroke width'
of the letters should cover most shapes and mean minimum extensions required....
Btw...i also challenged a friend (autocad expert user)
with these but he was not confident he could do any faster.
Work in progress!
EDITED: 2 Oct 2020 by LIGHTWAVE
Somehow, my custom style colors reverted to default. Colors were easily restored from AppData colors2020...3dm file.
-B
3723.50 In reply to 3723.48
The more speedy will be to found a 3D Font yet existing and with nurbs export 3D format!
Show messages:  1-10  11-30  31-50  51
