Remove Save (etc.) from right-click repeat?
All  1-6  7-9
3674.7 In reply to 3674.6
Hi NightCabbage, there is a list of all command names here:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#shortcutkeys
3674.8
Does this look like a reasonable list?
NonRepeatingCommands=delete undo redo new open opentemplate save saveas incrementalsave copy copyclipboard copyclipboardwithorigin cut paste pastepart export import importpart
3674.9 In reply to 3674.8
Hi NightCabbage, if it works for you then go for it! :)
Some of those could potentially be problematic as a default setting for MoI, for example being able to repeat import could be useful if you want to import a few different times in a row.
But if you find it getting in your way more often then you should add it to that list, I made that list customizable so that you are able to tweak this behavior to whatever works best for you.
Show messages: All  1-6  7-9
