Top 5 Features list for V3 !
 1-11  12-31  32-51  52-71  72-91  92-111  …  432-442
3628.52
MoI is the best nurbs modeling software!!! congrats Michael!
All the features that have been asked will be welcome but I have another one: Smooth. Some times when i make a network, the generated surface gets wrinkled. So smooth please!!
Another one is make2d like in rhino. Silhouette is fine when you are working with one object, but when there are objects behind other objects it makes lines that you dont want.
Deformers would be a great implementation for MoI too. Imagine one solid taking the shape of other one while embracing it!
Offset and shelling tools need to be improved. For example, when you offset too joined surfaces, some times it will create intersecting surfaces not joined.
Well thats all for now!
3628.53
Variable filleting, continuity options in the network command (so that creases are not visible when building something patch by patch), variable blending.
I consider those to be basic functionalities.
I'm sure SuperMike will come up with something awesome!
This is Sparta
3628.54
Here's my 5
1) Texture support
2) comprehensive training video
3) Rhino 5 compatibility
4) option to maintain Rhino texture coordinates
5) option to have objects grouped and named by Styles when exporting to LWO for modo
Thanks for the great software Michael!
Bill
3628.55
more tools for engineers. LOL
-array (either by angle, centerpoint, spacing, etc.)
-bend
-divide space (equally, by a number, etc.-sort of an offshoot to array)
-printed manual for $10 postpaid in the USA
Cheers,
Chris
3628.56 In reply to 3628.55
Hi Chris, just a quick note re: Array
The already existing Transform > Array > Circular command lets you create an array by an angular distribution around a centerpoint:
And the Transform > Array > Curve command next to it can create an array by evenly divided spaces as traveled along a path curve:
Some more information on these here:
http://moi3d.com/2.0/docs/moi_command_reference8.htm#arraycircular
3628.57
Hi Michael ...
My top five would include:
Dimensioning, text and line weight control (so I could use MoI as a drafting tool as well as a modeling tool) ... I guess that's 3
Printing from within MoI
Extrude is beautiful ... sometimes I would like to reverse extrude a face instead of having to trim with boolean difference.
MoI is wonderful for modeling ... I use it more and more for illustrating structures to clients ... it might be nice to be able to print to 3d pdf but that has already been discussed.
cheers,
eric
3628.58
I think my #1 feature for MoI would be a really basic renderer.
Something that can render a curve or a surface to a transparent PNG.
Also, export to SVG would be nice.
3628.59
Hello,
Even at this point MoI's 2D output is exceptional. Waiting for the icing on the cake in 2011. Some better filleting would be welcome, but I suppose that is more dependent on the library than MoI itself.
3628.60 In reply to 3628.56
Wow! Michael, I gotta RTFM. LOL I don't know how i missed that.
Thanks!
C.
3628.61
Very nice thing to appear, 2D functions for drawing creation.
João
3628.62
2 things I would like (not easy)
1) Variable radius fillet
2) Surface continuity matching e.g. for Network patch, sweep, loft.
3628.63
Variable radius fillet has been on my list for a long time...
Deformation tools would be a welcome addition as well
EDITED: 18 Dec 2010 by SCHBEURD
3628.64
Can a new user place a request for a V3 change? Hope so.
I am big on desktop customization and having two 24" monitors I would find that the ability to show all the tabs on the command palette opened at the same time to be very sweet (or as toolbars that can be docked or undocked).
_________________________
Don Cheke
Visit: Textual Creations
3628.65
I would love to see a simple renderer attached to MoI as well - having to deal with all the complexity (and flexibility) of large packages like Modo or C4D is not always necessary.
I would suggest looking into adding a simple exporter to Luxrender scene format; it's plain text and fairly uncomplicated. I would even say that writing UI for it would be harder than the export itself. :-)
3628.66 In reply to 3628.64
Hi Don,
Yes, certainly!
3628.67 In reply to 3628.56
Hi Michael;
How about rotate option so each element in array can be rotated similar to the Scale Array script.
Sharif
3628.68 In reply to 3628.67
Hi Sharif - don't forget that this thread is about your top 5 requests for v3.
Is that rotate array element the #1 request that you'd like to see as a new feature in v3?
3628.69 In reply to 3628.68
Hi Michael;
Here is my top 5 wishes for V3 in order of importance:
1. Object Grouping
2. Array group that can be edited later
3. Surface Paneling
4. Be able to Rotate and scale array elements as part of command (no script)
5. Improve scene Browser ( I have some ideas, see attached file )
Sharif
Size: 88.5 KB, Downloaded: 191 times, Dimensions: 702x1227px
3628.70
Must I point out 5 ?
Michael I got one only one big one
I want t splines for Moi.... ! Yes and its Christmas today so here you go.
Why is that only an option for Rhino users...... ?
I got so many shapes that I´d like to build like subdivision surfaces and join and boolean like nurbs.
that would also avoid many peoples problems with complex shapes and networking.......
plus if we had more ways to make smooth class a objects like car surfaces.... but that a part of
my t spline wish.......
Merry Christmas !
Peter
3628.71 In reply to 3628.70
Hi Peter, well T-splines is a plug-in written by a 3rd party that adds stuff to Rhino.
Plug-ins are built to a specific system - they use various services from the host application and are tightly connected with how the host mechanism is set up (like it's UI, how commands work, etc...) so anyway that's why you can't run t-splines directly on MoI.
It's kind of like how you can't take a water pump out of one car and just stick it in any other car - the connections and how a part like that fits into place are not identical between every kind of car.
Show messages:  1-11  12-31  32-51  52-71  72-91  92-111  112-131  …  432-442
