Top 5 Features list for V3 !
 1-9  …  130-149  150-169  170-189  190-209  210-229  …  430-442
3628.170 In reply to 3628.165
Hi Greg - SpaceClaim does have a lot of useful editing stuff in it - it's called a "direct modeler" or "history free" modeler which is a kind of different system than a history based one.
Basically instead of having a list of instructions on how the model was constructed like a history based modeler, it instead analyzes just the existing geometry and decides how to extend or rebuild pieces as needed when you pull faces around.
One thing that's really good about this system is that it works on any kind of imported file.
But it's also kind of more oriented towards editing more mechanical semi-blocky-ish type stuff - not so much for modifying swoopy flowing surfaces or things of that nature.
3628.171 In reply to 3628.137
I've been wondering about the symmetry thing. I've been wondering this whole time if I was missing something obvious.
top 5
symmetry, svg, collada, "lighting options/paintingbyuvmaps/indigo plugin", goz plugin (laughing... I know, I know, not a chance)
EDITED: 3 Aug 2011 by SOUTHPAWAMI
3628.172 In reply to 3628.171
Southpaw,
If you use the Mirror option or flip a copy of an object with the handles, tweaking or moving the primary object will cause the mirrored effect to happen to the copy.
Symmetry as a d-sub modeler uses is really not feasible in MoI
unless 1) you were allowed to edit surface and curve points forever (there seems to be a point where an object doesn't let you see the points anymore), and also made larger concentration of points more manageable such as with a soft election or rubber band method.
..and 2) or MoI employs the use of Components or active clones where changing one changes all, including additions of objects within the component (even it those clones were "mirrored").
3628.173 In reply to 3628.172
Mike,
I really don't understand all that well. I've run into about 4 types of modelers, nurbs, polygon, patch, and voxel, and I admit that as I write this, I don't know many of the limitations of each. MoI seems to be the only modeler built for a tablet and not "adjusted for use with a tablet" or "use tablet when sculpting & uv painting". MoI simply has a better user interface than most things out there.
Saying that, I still don't understand why in MoI can build a non-organic shape quicker than most places and yet can't seem to model a human to save my life. And when I pop into polygon modeling, I can have a human shape up quickly and keep carving it down to make it better and better. And I've yet to use patch, though I've never seen a human face made so fast in my life as with patch. And voxels seem to be the uber detailed organic type of modeling. I'm not sure why the tools work better for certain things, I'm really not. I'll keep reading the explanations, though I'm not sure when it will all just make sense to me.
3628.174 In reply to 3628.172
Hi Mike,
You'll always be able to see them if you use Edit > Separate to break things into individual surfaces.
It's when you have 2 surfaces that are joined along a trim curve boundary that you won't be able to see the control points - that's to avoid you pulling some points of one surface and opening up a gap in what used to be a joined common edge.
See this FAQ entry for some more explanation:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
3628.175 In reply to 3628.173
Woo-yah! :-)
Thanks Michael! It's really nice to discover new things about MoI. That'll come in handy.
Southpaw...
I think Michael will have a more concise analogy of the differences in the technology.
But, from my knowledge, the differences between the types of modeling technologies are:
D-SUBS: Based on polygons, are "cages" defined by points that are subdivided until a smooth shape is produced.
You can add endless complexity to the cages at the expense of adding an exponential number of polygons.
Editing can be kept fast by working in "low subdivision" modes where all you care about are manipulating the cage control points.
D-SUBS allow for complex organic creation with ease of editing. But if you want smooth polygon surfaces, you'll have to up the subdivisions.
VOXELS: Based on arranging points that are filled in with "bubbles" or surface thickness. This is how Z-Brush works.
With these modelers you can create freakishly complex organic models - even down to goose bumps. Polygon meshes can be interpolated later for use in layout and rendering apps.
VOXELS allow you to create complex, life-like models, but not the type of models needed for manufacturing where tolerances are high.
NURBS: Which MoI is based on, uses spline based math to build liquid smooth curved surfaces from relatively few control points.
The trade off with NURBS surfaces is that you can create a nearly limitless number of polygons that conform to the desired surface with a high degree of accuracy, but you lose the ability to model high detail, convolutions and bumps as you can with D-SUBS.
So, MoI's simplicity and ease of use is based on that premise.
NURBS are geared towards manufacturing and product creation, where mechanical accuracy are required.
3628.176 In reply to 3628.173
Hi southpaw,
Well, humans are a much different kind of shape than a mechanical object.
Mechanical objects are full of cut out areas and things like exact circular holes.
If you look at a human body, you won't find anything similar to an exact circular hole on it anywhere - it's a more sculpted form that doesn't have any perfectly straight parts to it.
Because there are no perfectly straight parts on a human body form, that also means that it is not defined very well just by a profile curve - sure you can draw a profile curve like the side profile of a face with a nose etc... but that profile does not "drive" the shape of the face - for example the nose is a small feature and quickly goes away as soon as you move by a small angle away from the side profile.
That is again very different than a mechanical shape - a mechanical shape is very well defined by side profile curves.
MoI is generally focused on a method of drawing shapes where you create profile curves to generate surfaces and also to cut them - that method is a great match for mechanical shapes but not a great fit for a human body.
Something that works more like sculpting where you are manipulating a 3d point cage (like you'll find in a polygon modeler) tends to work better for human body shapes, but then does not fit mechanical shapes very well.
Well, I'd say basically - if the object that you're working on is well defined by some profile curves (meaning a relatively small number of profile curves can generate the shape, some by creating extrusions or revolutions or things like that and others by cutting away material), then that's the kind of shape that will work really well with MoI.
If the object does not have any distinct driving profile curves to it (note just taking some random snapshot from one particular angle does not necessarily make for a profile that actually "drives" the shape) then you'll be more in sculpting and poly modeling (or voxel) territory.
Hope this helps!
3628.177 In reply to 3628.176
""""""""The trade off with NURBS surfaces is that you can create a nearly limitless number of polygons that conform to the desired surface with a high degree of accuracy""""""""""
NURBS are not polygons (Only on screen).. A NURBS surface is a mathematically difined surface, not polygons created from that.. A "MESH" is usually reserved for polygones... Usually, you wouldnt term anything in NURBS a mesh. But you can "mesh" your NURBS model, which would be converting it to some number of polygons, that try to conform to the pure NURBS surface.
3628.178
Mike,
The new ZBrush 4 lets you send your ZBrush model to be physically created to your requirements(you have to pay for it) and then your physically manufactured model ships to the address you specify. That's definitely voxel manufacturing. (At least, I think it is. Maybe it's converted?)
I do appreciate you taking the time to write about d-subs, voxels, and nurbs. I have found it easier to create organic with polygons before, though I am most curious if patch creation to polygon conversion will produce better end results in less time. Nurbs do seem to rock with man made things.
Michael,
Thank you for taking the time to explain all that. Makes sense, maybe it's the same reason why a single person is so much harder to draw than detailed architecture. I definitely see MoI as awesome for man made objects. I want to create people also, so I think I'll be trying patch soon. (And nurbs from moi are converted to polygons on export, right? So, I could bring nurbs and patches to the same environment for lighting and such because they'd all be polygons at that point, right?)
This leads me to another question. What are the limitations on the student version?
(apologizes for the rabbit trail - I do support a collada format in ver3... just to keep it on track.. lol)
3628.179 In reply to 3628.178
Hi southpaw - re: voxel manufacturing - that's certainly true that a voxel model can be produced as a physical object. But there's a lot more to the whole field of manufacturing than that - for example one big thing about part accuracy is making sure particular areas of the part are accurate enough so that they can be connected together with other parts. For things like that you can't just have something that looks generally circular for example - the geometry has to be accurate to a tight tolerance so you know pieces will fit together. In general both voxel and polygon sub-d modeling is more about smooshing stuff around so they have the kind of look you want, not about achieving a precise circular hole for mating parts and things like that.
So just in general polygon and voxel modeling are not widely used in manufacturing industries because of that, there are exceptions of course depending on what kind of thing is being manufactured.
Actually it will typically get converted to a polygon mesh if it's being generated on a rapid prototyping machine - usually STL format is used for that which contains triangles in it.
Yes, if you export to a polygon mesh format like OBJ, LWO, STL, FBX, or SKP.
There are other CAD export formats which contain the NURBS data, those are: 3DM, STEP, SAT, and IGES - these formats allow transfer of the NURBS data to other CAD programs.
Yup, sure you can combine together the outputs of various kinds of modeling programs within the same rendering program usually - most of the time for rendering output programs will output polygon mesh data.
There are no limits in the software - it's the exact same software as the regular version. The only difference of any kind is that a student license is non-transferable.
3628.180 In reply to 3628.179
Michael,
Thank you. You answered a lot of questions. I was sure I could use MoI, it just was starting to look like I need to use other things too.
Voxel manufacturing... that makes sense. Less than millimeter accuracy probably isn't a sculpting priority. I don't suppose perfect geometry is either. conversion to STL... cool, thank you.
Student license... thank you so much on that... it's as nice as rhino's student license. You programmed Rhino too, I thought.
So now I have a question. What is houdini doing(or how?) when I take a sphere, sub-divide it 3 or 4 or 5 times and then just carve right into it. I mean really, it's like a piece of wood or something. Is this sculpting? I really haven't seen any other non-voxel program do anything like this kind of thing without any slow down like houdini does... so it seems rather magical to me. Is houdini converting it to something else to play with it, or what?
3628.181 In reply to 3628.180
Hi Southpaw....
Here is a link that shows some results of a model i made in MoI and sent to shapeways 3d printing, and the result I recieved...
http://moi3d.com/forum/index.php?webtag=MOI&msg=2984.9
The only difference is now they have a $25.00 "minimum", so gone are the days of getting my model for only 9 dollars..
3628.182 In reply to 3628.181
That is really neat. It seems so foreign to simply give a 3d model and get a result for so little money. I could see how MoI was perfect for making that model too.
3628.183 In reply to 3628.182
Yes. it is very handy if you are going to manufacture somthing in very expensive material to be able to test it out first for $25.00! Actually, very cool for making little "Figures" too!
3628.184 In reply to 3628.181
Holy cats Burr! That's really awesome.
3628.185 In reply to 3628.180
Hi southpaw,
Yeah, if you want to build models that are not very well defined by profile curves (like human figures for instance), then you probably do want to use a poly/sub-d type modeler for those particular models.
I'm not really familiar with the carving function in houdini - do you have any screenshots of that?
It kind of sounds like you may be painting a displacement map on it though - that's a type of texture that can be applied to an object to make the surface push up or down.
You should be able to see a similar thing in ZBrush or 3D-Coat. ZBrush actually works by displacing polygons, and 3D-coat has multiple modes in it - it has a poly displacement mode and a voxel mode as well.
3628.186 In reply to 3628.181
Hi BurrMan are you a fisherman like me??
very nice work
3628.187 In reply to 3628.186
Hey spiderweb,
No, my brothers fish... I never had the patience for it..
But you did recognize a reel drag there... He makes custom components for reels, among other things... He also made the part.. I just modeled it with him.
http://www.rocketreels.com/videos/casting_v_1.wmv
3628.188
A offset curve command which does not yield a million overlapping line segments would be great 8)
Rainer
3628.189 In reply to 3628.188
Could that situation be fixed with the Rebuild command?
Perhaps a new addition to the Offset command would be an option to "interpolate" the result curve.
Show messages:  1-9  …  110-129  130-149  150-169  170-189  190-209  210-229  230-249  …  430-442
